Old 07-06-2010, 06:14 AM
richofoz richofoz is offline
Rep: 10 Posts: 2
advice on boat cradles?
Hi all first off I apologize if this is in the wrong section or has been asked a thousand times already!
I had a quick search but may be using the wrong terms...
Any way I'm about to pull the rotten sole out of my boat and I'm assuming there will be other stuff that needs to go too.
Whilst i have access I want to replace all of the old wood under the floor.
I have been told if I'm pulling out all of the stringers the boat should be on cradles to prevent it from warping.
I can see two obvious way to support the boat.
1. Making some v shapes out of timber to match the shape of the hull.
(Maybe 4 over the length of the boat which is 4.5m)
Or
2. full length skids that would support the full length of the boat just inside the chines..
Which of these would be my best option?
Thanks, Rich.
Old 07-07-2010, 02:24 PM
Herman's Avatar
Herman Herman is offline
Resininfusion.info
Rep: 1043 Posts: 1,268
Definately support the chines, these are a nice hard spot. Also support the keel, also a nice hard spot, and now you should be able to walk in the boat without the chines or the keel moving.
Supporting the relatively large area of the bottom is more difficult.
You could also get away with installing 3-4 supports athwartship, supporting the chines and the keel.
Old 07-08-2010, 09:53 PM
Rep: 1493 Posts: 7,447
Supporting the chines and keel is the proper way. Longitudinal cradles spread the weight on the framing you are removing.
Old 07-09-2010, 12:52 AM
Rep: 10 Posts: 2
Excellent, thanks guys.
Rich.
Boat repair, need advice. BiGs Fiberglass and Composite Boat Building 11 03-23-2008 06:17 PM
I need help and advice for my boat 66Tbird23 Fiberglass and Composite Boat Building 4 02-29-2008 01:25 PM
Need advice on boat plans determined_ange Wooden Boat Building and Restoration 19 07-09-2007 10:38 PM
Electric boat advice camglasgow Hybrid 3 04-07-2006 08:09 AM
Trick Cradles aitchem Sailboats 13 01-19-2006 09:58 AM
