| ABS deck plates - fuel tanks? I'm considering using Beckson ABS deck plates(screw lid, neoprene seal) as diesel fuel tank (composite f/g) inspection hatches. Any problems with compatability of epoxy seal & ABS?. If so, are there other sealants available? Your comments & opinions are appreciated. Regards, Hank. |
| After posting this thread, I came across some related threads posted by Jeff & Tom Lathrop (2001). I have built 2-100 gal. diesel fuel tanks in composite, 1/2" marine ply,F/Ged & taped, epoxied, baffled, and used an epoxy tank coating mfg'd by Ameron, available in gal. sizes. After conversation with several local amateur builders who have used the method successfully, I,m confident that I have a durable and safe tankage system. Accessing the proper tank fittings seems more of a problem. Regards, Hank |
| I'm not completely familiar with Canadian regulations. It may not be legal to use plates like those. Also, they are not built to withstand pressure from behind. With fuel surging at speed they are likely to pop open. How much fiberglass is over the 1/2" plywood? Have you calculated the slamming loads?
__________________ Gonzo |
| epoxy fuel tanks | Boatbuilding | 24 | 08-14-2008 04:36 AM | |
| Luhrs T-29 (1995) diesel inboard converted to outboard | Iya | Boat Design | 13 | 03-07-2007 07:48 PM |
| Coating of Fuel Tanks... | blueyachtr | Boatbuilding | 2 | 09-28-2005 01:27 AM |
| Easier way for balsa core deck replacement? | pago cruiser | Boatbuilding | 4 | 06-01-2005 07:20 PM |
| Fuel tanks | zack | Powerboats | 6 | 07-05-2004 04:43 PM |
