Old 01-17-2008, 10:37 PM
dannie_ga dannie_ga is offline
Rep: 10 Posts: 3
About make fiberglass in keel.
I had question for the keel.
The boat is 32' deep-v type, use 350hp stern drive, how much depth is needed for the keel? My friend told me only 3~4mm is enough, is possible? And which specifications of fiberglass is needed using? 450,800? Echo how many layers does it cost?
Thanks all!
Dannie
Old 01-17-2008, 11:53 PM
Rep: 2891 Posts: 8,798
A structural laminate (like used in a keel) needs to be calculated by the loads it may be expected to tolerate, with a reasonable margin of safety worked in. Impact and penetration resistance are also a considerations.
With some experience a decent laminator, familiar with the general class of vessel they're working on, can make a fair guess as to the laminate schedule. If in doubt, the wise course of action is have a person with known engineering or lamination abilities, rough in a schedule for you.
Short of this, you can use Dave Geer's guide lines ("Elements of Boat Strength") on laminates for the type of build you are working with.
Dumping keel and mast to make boat "unsinkable" SeaSpark Sailboats 43 01-29-2008 06:30 PM
crack on keel lead cast on fiberglass santana 30 marto Sailboats 5 06-06-2007 09:26 PM
i need to know how to make a fiberglass or composite plug or mould need help badly Islandboy Fiberglass and Composite Boat Building 6 04-06-2006 07:17 PM
how do you make your own fiberglass body huntermike32 Fiberglass and Composite Boat Building 12 11-02-2005 06:43 PM
how to make Keel in aluminum AliBaba Metal Boat Building 3 04-29-2005 02:01 AM
