Old 06-25-2007, 08:31 PM
jksoft jksoft is offline
Rep: 10 Posts: 14
25 yr old foam sandwich constructed sailboat
I have the opportunity to purchase a sailboat, approximately 25 yrs old, that is built with foam sandwich construction. It was designed and built as a racing boat and even won a trans atlantic race. My question is in regard to the longevity of this type of construction. I realize most racers like this are designed with a short lifespan in mind and it seems that this one may be pushing the limits, but as far as I know, it is still structurually sound. It has not been surveyed yet. Knowing what you know about this construction method, would you even look at this boat? I plan to use it for daysailing and cruising here in the Caribbean, but I don't want something that has exceeded its useful life expectancy.
Old 06-26-2007, 01:29 AM
Rep: 2891 Posts: 8,798
The only real advise is to seek a good surveyor, as you know the other obvious things to consider about a worn down racer. The method is sound, but every method can have issues of some sort develop, for a host of reasons, which is why you need the survey.
Old 06-26-2007, 09:36 AM
rturbett's Avatar
rturbett rturbett is offline
Rep: 22 Posts: 139
Don't forget that as a racer, the boat was worked hard. Survey time.
Old 07-27-2007, 09:30 PM
the1much's Avatar
the1much the1much is offline
huh? hehe ;)
Rep: 547 Posts: 3,949
the first thing i would check is the keel weight, alot of them racers are FREAKS , lol and take alot of wieght out of the keel to make the boat lighter
1983 foam core sailboat repair Dimitris Fiberglass and Composite Boat Building 0 06-25-2007 11:09 AM
Sandwich Superstructure fencer Fiberglass and Composite Boat Building 5 07-01-2005 10:13 AM
PVC Foam or Polypropelene Honeycomb sandwich core plimsoll_line Materials 7 03-20-2005 07:00 PM
Composite foam board sandwich technique scottperkinsusa Boat Design 11 09-18-2004 09:30 PM
Sandwich proportions Alik Boat Design 2 04-10-2004 02:23 PM
