| 20 ft bertram transom replacement hi every1, need some advice on replacing the transom on my 1969 sportsman , read where cutting the outer skin off to rebuild but my transom is very concave question will it work o.k. or do i need to cut the inside..any1 ever did a 20 ft moppie or a sportsman thinking both hull are similar....ty for any help |
| Keep the outside skin if at all possible. I am int he middle of a rebuild of a 22 Aquasport and had to take both skins out and build a mold. There are pictures here: http://209.190.4.227/forum/viewtopic.php?t=11294
__________________ www.boatbuildercentral.com |
| Cut the inside and use a flexible core material. cutting the outside will leave you with lots of extra work finishing. Nida core has worked well for my transom. |
| 1981 Chaparral 198 Bowrider Stringer/Transom/Floor Replacement (*Long*) | Geoffman72 | Fiberglass and Composite Boat Building | 5 | 07-10-2006 10:41 PM |
| Transom Replacement Foam vs Marine Ply | MJB | Materials | 3 | 06-14-2006 04:52 PM |
| 11' Inflatable - Transom Replacement | chrismiele | Wooden Boat Building and Restoration | 0 | 06-08-2006 05:27 PM |
| 46.6 Bertram | seadogs20 | Marketplace | 0 | 01-10-2006 10:17 PM |
| transom repair/replacement? | ldolbee | Fiberglass and Composite Boat Building | 5 | 01-13-2005 11:27 AM |
