Old 03-23-2006, 02:13 PM
AhmicLake AhmicLake is offline
16' Garwood with Fibreglass Hull
Hello,
I have a full set of plans for a 16' Gentleman’s Racer. I also have the plans in CAD form with the cutting files for a CNC router/cutter.
My thoughts were to have the frames cut out of 3/4" marine ply on a CNC machine and use them as a male mold (strong back) to build a foam core hull.
Then once the hull was completed on the outside, I would epoxy the forms into the hull.
I've come across many examples of foam core constructed sailboats on the net but very few powerboats.
The original boat had the hull topsides planked in 3/8" mahogany and the hull bottom planked in 5/8"
What type of foam and thickness should I look at using to replace the traditional wood planking??
I would like to use the West Epoxy system on the whole boat but I'm not sure how to finish coat the outside of the hull. Do I mix an epoxy mixture with a colour agent. or do I use a two-part paint to obtain my final finish?
When I'm all done my goal is to have an easily constructed Fiberglass hull with a black exterior, a traditionally planked deck, and a modern small block Chevy as my engine.
Thanks for any help and suggestions. I've had a tough time rounding up good books on the subject of foam core construction so any readings you could recommend would be great too!
Old 03-23-2006, 04:16 PM
jimslade jimslade is offline
Rep: 14 Posts: 304
Glen L has a book on fiberglass boat building that deals with foam core construction. Check out their web site. 3/4 inch nida core is what I would use.
Old 03-28-2006, 09:38 PM
rustnrot rustnrot is offline
Rep: 10 Posts: 6
I have a female mold of an original Gar Wood speedster. I lay up a fiberglass hull then "plank" it above the waterline with mahogany. A CNC router cuts the deck beams and all planking and other parts. Email me for more info.
I'm thinking about using a 40' by 16' hull. Looking for a builder and pros and cons. David Dewberry Boat Design 1 03-23-2006 09:30 AM
Fibreglass Boat Plans Please, Or help of buying a hull Fingers_21 Powerboats 0 01-10-2006 07:02 AM
Looking for 16' -18' tunnel hull Collier Marketplace 0 08-16-2005 01:47 PM
rib or fibreglass? petergcmc Powerboats 2 04-14-2004 02:33 AM
Fibreglass - how to ChrisGibbs Materials 5 11-06-2003 08:58 AM
