Old 03-09-2006, 06:13 AM
Adam_melb Adam_melb is offline
Rep: 10 Posts: 8
12ft v-nose punt laminate schedule
G'day everyone,
have just finished drawing a little v-nosed punt. will be used primarily as a fishing boat, throwing lures at docks and marinas ...etc. the boat will be an epoxy, foam, glass sandwich. will also be vac bagged.
at this stage i plan on using a pvc core and bi-ax (0/90) glass.
i am unsure of foam thickness (10mm?) and density(80kg/m3??).
also am not sure as to what weight and how many layers of glass on the inside and outside of the hull.
I'm not trying to reinvent the wheel and weight isnt super critical, but i would still like it to be light.
could anyone give me a starting point as to what materials are needed in the layup.
any advice much appreciated
Cheers adam
laminate schedule bearwen Fiberglass and Composite Boat Building 2 11-05-2005 11:28 AM
MiniTransat laminate schedule nemo Sailboats 9 08-20-2005 04:09 PM
Square nose speedboat Jayel Boat Design 2 04-21-2005 08:55 AM
Laminate schedule jfblouin Fiberglass and Composite Boat Building 3 01-23-2005 01:39 PM
Laminate Schedule SOB Fiberglass and Composite Boat Building 2 10-03-2004 07:22 PM
