Old 02-09-2005, 03:06 PM
Dallas_B_ Dallas_B_ is offline
Dallas B
Rep: 10 Posts: 15
125 Force prop (location)depth
On a bay boat, how far below the center of the boat is the prop to be located (in water)? Dallas
Old 02-09-2005, 05:53 PM
Richard Petersen
Do you have a home built or a factory built boat? What type of use do you want?
Old 02-09-2005, 06:17 PM
Dallas B
Rep: 10 Posts: 15
Its a fiberglass boat.....factory name ????. 8' wide 26' long.
Old 02-09-2005, 09:46 PM
Ssor Ssor is offline
Rep: 10 Posts: 174
Was it designed as a power boat or a sail boat? does it have a transom cut-out for an outboard motor ? did it at some time have an inboard engine and a though the stern drive? or does it have a hole in the bottom for a propeller shaft? Was it fitted with seats and oarlocks? what bay are you thinking about? Galvaston bay? something smaller? something larger? When you speak of 125 force prop, what are you referring to?
Before your questions can be answered you must provide more information about the boat.
Old 02-09-2005, 10:01 PM
Dallas B
Rep: 10 Posts: 15
Power Boat.....yes.......no.......no.....Port Mansfield, Texas ......125 Force Motor with prop......
Old 02-11-2005, 11:46 AM
Rep: 10 Posts: 174
The prop needs to be deep enough to not ventilate when running at speed. The engine is heavy enough to require hoisting equipment, so I would think that the dealer would be able to give the best advise. The lower units on outboard engines are pretty standard with some variation. The boat manufacturer knows this and makes the cutout accordingly. I doubt that you have cause for great concern here. If you were trying to optimize this for speed then the problem would require some very care full study. Do you plan to self install?
Solomon Technologies - "Electric Wheel" electric motor propulsion systems lockhughes Hybrid 228 10-12-2011 04:00 PM
Human Powered Boat SolomonGrundy Boat Design 346 11-10-2009 11:01 PM
Option One - how big Willallison Option One 43 12-20-2005 05:44 AM
Offset single prop - which direction? Ben Lindenberg Propulsion 7 11-10-2004 12:53 PM
sea ray prop for planing jfc52 Propulsion 20 09-17-2004 08:09 PM
