Old 04-24-2008, 10:47 AM
stan54 stan54 is offline
Rep: 10 Posts: 7
1-part Topside Primer over 2-part Primer
Hi, I'm new to boat painting and I have a small problem. I have read that layering a two-part paint such as Interlux Perfection over a one-part paint like the Interlux brightside, creates a chemical reaction and it doesn't work. The previous paint job on my 20' fiberglass cuddy cabin, used a one-part paint. Therefore the primer was also the one part primer. Right now I have it sanded down to the primer. I want to put a two part top side paint because I want to do the job once, but do it right. How should I go about preparing for a paint like perfecion or awlgrip? Should I use the two- part primer like epoxy primekote and then the two part paint over that? Will the epoxy primekote, react with the one-part pre-kote? Or should I just try to chemical strip the rest of the primer and then use the epoxy primekote and perfection? If you have any ideas about other techniques or products, feel free to point them out. Thanks
Old 04-24-2008, 11:17 AM
the1much's Avatar
the1much the1much is offline
huh? hehe ;)
Rep: 547 Posts: 3,949
sand with 220,,primer with 2 part over that,,sand with 320,,then paint ya 2 part topside
hehe ,,,,,Jim------>
Old 04-24-2008, 01:27 PM
Rep: 10 Posts: 7
Thanks for the quick reply. I was actually reading some of your post about painting before. So, the two-part primer isn't going to react with the one-part primer and it will provide a barrier for the two-part topcoat?
Old 04-24-2008, 06:20 PM
Kaptin-Jer's Avatar
Kaptin-Jer Kaptin-Jer is offline
Semi-Pro
Rep: 206 Posts: 563
First things--Only post in one forum - you need to delete this in the design forum
I think you'll find most (not all) the people that hang around this forum are partial to Awl Grip. Even if you use Sterling I would still recommend priming with Awl grip 501 Primer. There have been a few good threads regarding painting. Look through this one. The AWLGRIP Knowledge challenge
--and don't let Jim scare you off
Old 04-24-2008, 07:35 PM
the1much's Avatar
huh? hehe ;)
yes hehe
Old 04-24-2008, 07:50 PM
Rep: 10 Posts: 7
I'm apologize for posting in two forums. I was just hoping more people would see it so I could finish my boat sooner. Anyways, like I said I was wondering about the compatibility of paints. I read through some of the forum of the link that you posted, and found out some helpful tips, but I don't think I saw anything on that issue. I also did a search on interlux perfection vs awl-grip and found that awl-grip had great results but was more difficult to apply. People also found perfection to have similar result if not slightly worse but it was easier to apply and it leveled itself out really well. The owner of a local marina said he used perfection with amazing results. I would like to use perfection, but if you guys think that awl-grip is significantly better, I will definatly use that instead. Thanks for the input jerry and the1much. any help is greatly appreciated.
Old 04-24-2008, 08:06 PM
the1much's Avatar
huh? hehe ;)
BOUT TIME I CAUGHT YA KAPT.,,,,and awl-grip is way better then anything else,,,and isnt any harder to spray or roll then any other 2 part.,,its just that people that use awl-grip EXPECT a perfect job,,,but if you prep,,and spray the same way for both kinds of paint,,,,its all the same.,,but,,,as Kapt. said no matter what i used,,,i'd use 545 awl-grip primer.
Old 04-24-2008, 09:14 PM
Kaptin-Jer's Avatar
Semi-Pro
Rep: 206 Posts: 563
The 1 much pretty much said it all. Except I don't think he caught the part that you were going to Roll and Tip, so I guess we will not be hearing from him much
Ya Jim I was actually spending some time in another forum getting tips on rebuilding my transmission. This one was a bust in that regard. Also I was called down to the marina yesterday they are going to sell a 45' steel sloop and told me to take whatever I wanted. Got my mast!! and Saturday I'll salvage some deck hardware. Haven't been below. Salvage is fun. Re-built two boats this way. Free!!
Sorry Stan, Had to say hello to my bud
Old 04-24-2008, 09:21 PM
Rep: 10 Posts: 7
It's cool jerry. I do plan on rolling and tipping btw. The 545 primer shouldn't react with the primer I currently have on the boat right?
Old 04-24-2008, 09:30 PM
Kaptin-Jer's Avatar
Semi-Pro
Rep: 206 Posts: 563
No the Awl Grip primer will react as a bonding agent between the old and new. Much says sand the old primer down to 220, I'll buy that, but sand the last coat of new primer with 325.
Old 04-24-2008, 09:52 PM
the1much's Avatar
huh? hehe ;)
hehe,,,im jealous ,damned "transmission" people,,hehe
and kapt.,,,we're only 5 grits off,,,,i said sand the 2 part primer with 320 hehe
and GREAT bout the mast!!,,see,,,now just a few more days and a "tranny" will show its head ,,,and i LOVE salvage work,,hehe ,,specially FREE
and this dude is snailing this paint?,,,,never mind,,,,i dont even wanna talk to him!! hehe
Old 04-24-2008, 10:03 PM
Rep: 10 Posts: 7
snailing?
Old 04-25-2008, 06:48 AM
the1much's Avatar
huh? hehe ;)
roll and tipping,,hehe,,,i was jus playing hehe
Old 04-25-2008, 06:45 PM
Kaptin-Jer's Avatar
Semi-Pro
Rep: 206 Posts: 563
Yep, seems like I'm always 5 up on you. Right or wrong
Stan, I told you not to let him get to you. He is just jealous that we can roll and Tip. He uses pictures of my roll and tip jobs for his portfoilo.
Old 04-25-2008, 06:48 PM
the1much's Avatar
huh? hehe ;)
shhhhhhHHHHhhh,,,ya promised not ta tell hehe
1-part Topside Primer over 2-part Primer stan54 Boat Design 0 04-24-2008 10:45 AM
Can I use this stuff for a two-part poly primer? mongo75 Fiberglass and Composite Boat Building 0 09-16-2007 10:53 PM
Are one part polyurethane topside paints gas resistant sbklf Fiberglass and Composite Boat Building 6 08-02-2007 12:14 PM
Are one part polyurethane topside paints gas resistant sbklf Materials 1 08-01-2007 09:55 AM
do i need to primer before paint? revshot Fiberglass and Composite Boat Building 5 03-19-2006 01:29 PM
