| wiring diagram I am installing a 12 volt system in a new custom boat. Nothing is installed at this point. When I first checked here for info I saw that Brotherton's 12 Volt Bible for Boats was recommended as a starting point. So I am mostly finished reading and have come up with the attached wiring diagram. The panels and switch are already purchased, no batteries or bus bar yet. My motor (Suzuki DF 250) has a high output alternator, and my switch has an alternator field disconnect (F1, F2). Not real sure what to do with F1 and F2, Also, should the bus bar be close to the batteries or the panels? Am I even close?? |
| The F terminals are for the field on some old style alternators. You can also use it to power the auto switch on the bilge pump because it never switches off. It looks OK. Make sure you use wire guage of the right size for the length of run.
__________________ Gonzo |
| Gonzo ,I think you may have your terminals muddled. |
| Ooops as you were, sorry ,missed auto disconnect |
| Thanks Gonzo, so late model outboards probably dont need F1 and F2 |
| boat wiring diagram | mountainmn | Outboards | 12 | 07-14-2010 10:44 PM |
| Wiring diagram for an O/B. | LP | Electrical Systems | 14 | 05-02-2009 07:27 PM |
| wiring diagram for `46 catamaran | guest200901 | Multihulls | 9 | 09-27-2007 10:03 AM |
| Standerd wiring diagram | sharkfish | OnBoard Electronics & Controls | 2 | 05-23-2007 01:31 AM |
| Wiring Diagram | scanvictoria | Electrical Systems | 2 | 06-12-2006 10:07 AM |
