Old 04-06-2007, 01:43 PM
CLUTCHfan CLUTCHfan is offline
Rep: 10 Posts: 8
Where can I find inexpensive Buss Bars?
The only Marine supplier in my area that carries them wants my first born son for Buss bars ($35-$40 apiece) I found a place on ebay, but would rather buy from an actual online store/distributor. I didn't know if there was an online store that people have had good experiences with that had good deals on electrical components for my boats.
I may be fat and ugly, but at least I don't have any money.
Old 04-06-2007, 02:05 PM
KnottyBuoyz's Avatar
KnottyBuoyz KnottyBuoyz is offline
Provocateur & Raconteur
Rep: 578 Posts: 604
www.bestboatwire.com
Tell Sylvie Rick from Iroquois sent ya.
Old 04-06-2007, 11:42 PM
Frosty's Avatar
Frosty Frosty is offline
Rep: 1528 Posts: 5,519
You may think that only boats use them --I did.
Try your local electric store. I can buy them here very cheap at any electrical shop.
Square brass bar with tapped hole and screws and two plastic ends to support them.
Old 04-07-2007, 06:07 PM
tja tja is offline
Rep: 11 Posts: 125
Tja
Hello, What size do you need. I buy at OEM pricing and could give you a good discount. Tom.
Old 04-08-2007, 04:12 AM
Lancerbye's Avatar
Lancerbye Lancerbye is offline
Rep: 10 Posts: 85
Check your electrical wholesaler they should have them in brass with brass screws or in copper(1/4")x 1"or bigger 3 to 8ft strips. Stay away from marine supply stores for this. They usually mark them up by about 400%
Old 04-09-2007, 03:30 PM
Rep: 2891 Posts: 8,798
SkyCraftSurplus.com
Old 04-13-2007, 07:47 PM
Carioca Carioca is offline
Rep: 26 Posts: 59
Initially, I used to buy my buss-bars at marine chandlers.
Now I make my own, boring and tapping copper strips of the required thickness, width and length.
For good measure, the copper strips are then tinned in a crucible holding molten solder. Dip the strips into the bath and wipe off excess molten solder with (clean) cotton fibres (stuff that mechanics use). As you wipe off, you will notice the solder clinging to the copper strip.
The tapped holes are finally cleaned out with a tap tool and all is ready to go !
Would someone find this useful? lewisboats Boat Design 1 11-08-2006 12:44 PM
Inexpensive Source For Spline Weights SplineWeights Education 4 08-15-2005 05:19 PM
where to find 1/8 plywood? kenfyoozed Materials 1 04-01-2005 01:26 PM
Looking for an inexpensive Naval Architect to design a Submarine SSM Services & Employment 2 08-24-2004 02:03 PM
Looking for inexpensive naval architect or yacht designer Albert Services & Employment 6 06-03-2003 08:56 PM
