Old 03-25-2011, 02:12 AM
Boston's Avatar
Boston Boston is online now
Rep: 1457 Posts: 3,355
whats the best RPM range on this motor
I've got a 10 amp 24 volt DC motor 2040 rpm that I'm using to drive a geared pump with and I'm curious about a few things. I'd like to use a simple rheostat to set the pressure on the pump head by adjusting the RPM of the motor but that means the motor will unlikely be rotating at its optimal speed. What will that due to its efficiency and power consumption. And will it damage the motor to run for a few hours at a time significantly below its rated speed.
I've got a fluid pressure regulator that I"ll be using as well to fine tune the pressure but I don't want To much overpressure. The pump head has 1/2 fittings and the pressure regulator has 3/8 so I'm a little concerned that to much pressure might result in added resistance on the pump and end up being even more wasteful than if I simply slow down the motor.
thanks in advance
B
I am skeptical of the deniers diatribe
Old 03-25-2011, 11:29 AM
CDK's Avatar
CDK CDK is offline
retired engineer
Rep: 1425 Posts: 2,252
The motor will happily turn at a lower rpm but the rheostat will dissipate a lot of heat and must have a means to get rid of it. Your motor has 2.4 ohms internal resistance, so with a 2.5 ohms 100 watts rheostat you can set any rpm between <1000 and 2040. At minimum speed both will each dissipate approx. 100 watts.
And remember that every watt going into the rheostat is wasted. A switching power controller is a better solution.
Old 03-25-2011, 01:19 PM
Boston's Avatar
thanks
I'll see if I can find that power controller
Old 03-27-2011, 10:09 PM
Boston's Avatar
I just realized the batteries in my truck are in parallel rather than wired in series so now I have a 24 volt motor and a 12 volt system
brilliant eh
I saw two batteries under the hood and immediately assumed I had a 24 volt system
Old 03-28-2011, 11:47 AM
Boston's Avatar
the best solution is to just stick a 12 volt motor on it but, it would mean major modifications to the present set up = whopping pain in the ass and after I add up all the parts I'm still looking at $250+ to fit a 12V motor.
so I'm wondering, could I get two new batteries wire them in series and charge them with the 12V alternator but isolate them with diode bridges = same money without tearing all my hard work apart, and I end up with a few extra batteries.
thanks
B
Old 03-28-2011, 11:59 AM
Brian@BNE Brian@BNE is offline
Rep: 140 Posts: 222
You do like to make things complicated, dont you? What about an inverter or transformer?
Old 03-28-2011, 01:33 PM
CDK's Avatar
CDK CDK is offline
retired engineer
thanks
B
The prizewinning solution for your project is Willallisons link in post #3:
24 volts from a 12 volt supply
Old 03-28-2011, 03:53 PM
Boston's Avatar
hey Brian ya, I'm an over complicate it magnet what can I say, but my stuff does turn out pretty cool by the time I get all the kinks worked out. Once I get this electric figured out then its on to the heating element for this thing.
OK CD great suggest, just one glitch, I have two batteries in parallel now, so if I add a third I'll have a dissimilarity that will adversely effect battery life if nothing else. I could add two batteries and have two in parallel on each side of the circuit, that would at least balance out the draw on each set.
hmmmm two batteries aren't all that expensive so I think that wiring plan would work fine, assuming my thinking is correct on being able to balance the system I have by adding two bats instead of just one.
Brian
I think a transformer would work but its way more costly that a couple of batteries and a switch. I'll look it up and see what I can find but I suspect its going to be the more expensive option
thanks guys
B
I'm a bit fuzzy on what exactly the head lights are doing for me but they are a good indicator of power on and power off.
the latest configuration of the tank
I had to move the pressure regulator to the other side of the first filter set which also shortened the overpressure return line and loop the feed line off the pump head but all in all I kinda like it better this way. I'm still fiddling with the centrifuge/pressure gauge/feed line configuration.
Old 03-29-2011, 12:41 AM
Boston's Avatar
Ok found a converter http://www.powerstream.com/dc24.htm seems like its pretty cheap but it does mention voiding warranties, not sure what thats all about but it would end up being the simplest and cheapest solution at $154. also might make a nice in line oil heater.
Thanks Brian
Can a motor produce the same HP at different RPM with different Loads hwsiii Props 40 05-31-2010 03:05 AM
Cruising range question htoykoc Diesel Engines 6 11-09-2009 04:47 AM
trolling motor prop rpm? amaurer Props 1 09-27-2009 11:03 PM
need higher rpm range on chrysler 318 LEASEGUY Inboards 10 07-21-2007 12:45 AM
Salary range . . . ABoatGuy Education 5 08-16-2005 01:28 PM
