Old 08-16-2009, 10:08 PM
markapana markapana is offline
Volvo/Penta Electrical outdrive lift motor
Just bought an 1979 Renken with a AQ120 and a 270 outdrive. The previous owner replaced the 4 wire lift motor for a 270 outdrive with a 2 wire motor and wired for a 280. Lift had become in-op and I assumed that relays could be the problem. I went to a NAPA store and replaced both with 30a 5 terminal relays and rewired exact as soon as I went to touch the positive battery cable ground wires started to smoke. I have double checked the ignition switch, motor, up/down switch and of course the terminal leads to the diagram. I'm stuck..........any advise
Volvo Penta With Outdrive No Reverse flatcapsteve Sterndrives 1 07-22-2008 05:20 PM
Is it possible to swap my motor (1969 volvo penta) into a older tempest niv5674 Sterndrives 1 02-04-2008 04:41 PM
Milky outdrive oil Volvo-Penta jflongwell Sterndrives 5 12-19-2007 10:16 AM
Is a Volvo DPX-A Outdrive w/147:1 Gear ratio a good outdrive ezfriday Propulsion 4 09-20-2006 06:26 PM
volvo penta 200 outdrive noise cmzracing Propulsion 2 01-02-2005 04:48 AM
