Old 11-16-2007, 01:59 PM
dereksireci's Avatar
dereksireci dereksireci is offline
Rep: 37 Posts: 163
Trolling Motor Harness
What are builders typically installing for trolling motor wiring? What gauge? How many wires?
The Minn Kota wants you to connect the batteries in series and then run two wires to the motor.
I believe the Motor Guide unit uses a hot lead from each battery and one ground wire.
Naturally device amperage and the length of the run determine wire guage. We use 6 gauge.
We install the harness and plug and the customer installs the trolling motor of his preference. So it's hard to cover all possible scenarios. What are other builders doing?
Trolling motor powered surfboard: prop problems joeforte Props 25 04-16-2010 12:46 PM
Most effecient trolling/cruising motor? juiceclark Boat Design 0 10-18-2007 11:17 AM
Jon Boat: Mounting a Trolling Motor? Ronnie Hilton Boat Design 3 04-21-2007 10:33 AM
Bayliner 175 bow trolling motor, how? boatmen Powerboats 3 01-24-2007 08:52 AM
Trolling motor for aux power LP Sailboats 23 04-27-2006 12:10 PM
