Old 01-22-2006, 09:04 AM
paularey paularey is offline
Rep: 10 Posts: 32
Thru-hull Transducer mounting/fairing technique..?
I am installing a new RayMarine depth finder in my Catamaran which is currently in the water. I want to make and bond my inside fairing block for the transducer (1.87 inch shank). Also I’ll probable finish the job when I’m beached somewhere so I need to have all my prep work done so the job goes quickly. Any tips on a good fairing material and how to best approach this project appreciated.
Old 01-24-2006, 06:32 PM
Corpus Skipper's Avatar
Corpus Skipper Corpus Skipper is offline
Hopeless Boataholic
Rep: 173 Posts: 604
I usually use marine ply (laminate for thickness) or a hardwood block. I have used Starboard too. If you know the deadrise angle, just set up a table saw and make your cut. Otherwise, I use a bevel guage and "eyeball" a transverse member for "level" to get my angle. Pre-bore your 1.87 hole and bond the block with the goop of your choice (I use epoxy, 3M 5200 is good too). I would 'glass the block completely if it's wood, so give all your corners a 3/8" or so radius before sticking it in for good, so you can 'glass the whole thing easily. When you're ready to cut the hole, drill a pilot hole dead center from inside, then hole saw from the outside. Your pilot hole will give you the right angle, so don't force it. On a final note, if you have a cored bottom, I would cut out the coring material about 1 inch around your block, build up the outer skin with as many layers of alternating mat and roving as it takes to give you about half the thickness of the coring material (more if you want to really "bullet proof" the thing, and lay several layers of mat over the exposed coring to seal it up good, again giving everything a nice radius so the 'glass will lay nicely. Then install your block. Have fun
Craig Cavanaugh
Silver King Custom Marine
No shoes, no shirt, no problem!
Depth Transducer Mounting Without a Through-Hull JPC Fiberglass and Composite Boat Building 7 02-23-2006 08:54 PM
Fairing a cone to hull in maxsurf Grant Nelson Software 3 01-07-2006 10:12 AM
Hull fairing software: Rhino vs. Prosurf/FastYacht chomchan Software 2 10-18-2005 01:38 PM
Design a display unit for speed transducer! bing2005 Boat Design 2 01-31-2005 03:37 PM
Hull fairing software (big ship) MaciekP Software 12 03-31-2004 02:24 AM
