| btw, I''m bulding a wooden boot, without stationary engine, wooden mast and I wonder how to protect crew, boot and circuit against lighting ? I heard about metal plates below water line. What is the best way to ground all 12V circuit . Do you know some tips in this case ? ![]() |
| You do not need to do anything, lighting will completely ignore your boat. To avoid build-up of static electricity in extremely dry conditions, wire the 12V negative to a submerged metal object like a small zinc anode or a stainless steel plate.
| Navigation Light Switch Panel with warning lights | Blain Albin | Electrical Systems | 10 | 03-31-2011 07:12 PM |
| Battery switch question | Rich35758 | OnBoard Electronics & Controls | 4 | 09-03-2008 11:48 AM |
| Switch Panel Power Consumption! | samaki | OnBoard Electronics & Controls | 4 | 02-28-2008 07:33 AM |
| temperature switch | flyguy | Propulsion | 4 | 08-29-2006 08:56 AM |
| yamaha key switch question | wd jones | Powerboats | 2 | 04-06-2005 10:43 PM |
