Old 03-11-2007, 10:44 PM
sdb sdb is offline
Switch with 2 bank charger
  • I want to power my 12V trolling motor with one deep cycle battery at a time.
  • I have two batteries, a dual bank charger, and a 1,2,both,off switch.
  • I don't want to have the batteries in parallel. I want them independent, using only one at a time.
  • There is not a motor/alternator in the system.
With that said, how do I wire it?
I was planning on:
1) Taking both battery post negatives together to the negative of the trolling motor.
2) Taking the first battery post positive to the #1 input on the switch.
3) Taking the second battery positive to the #2 input on the switch.
4) Taking the positive wire on the trolling motor to the "feeder" (last of the three posts) on the switch.
5) The 2 bank charger has 2 postive and 2 negative outputs which would go directly to the batteries.
So I started doing this and got concerned about the negatives. If the negatives are tied together;
1) Does this affect the 2 bank charger?
2) Does this affect the battery that isn't "switched on" during operation?
Thanks for your help!!!
Old 03-12-2007, 04:20 AM
Lancerbye's Avatar
Lancerbye Lancerbye is offline
Rep: 10 Posts: 85
The negatives being common is in fact common.(pardon the pun) The system you discribed should work fine. The multi bank chargers usually allow for a common negative and the positives are isolated so you won't get drain from the none working side.
temperature switch flyguy Propulsion 4 08-29-2006 08:56 AM
Ignition Switch Wiring???? bgull2 Outboards 0 05-29-2006 04:14 PM
AC Auto Transfer Switch bcervelo Electrical Systems 1 05-09-2006 12:06 AM
yamaha key switch question wd jones Powerboats 2 04-06-2005 10:43 PM
Aluminum Bank Dory jsirm Metal Boat Building 3 03-11-2005 04:37 AM
