| Surge protection for inverters As I work along on my 73 Silverton project I have time to think as I perform some of the mindless tasks (such as just spending about 10 hours over three days sanding multiple coats of who knows what kind of paint(s) off the cockpit floor and engine compartment cover. (and yes I wore a respirator!) I have the electrical system figured out and partially wired in at this point. When I get ready to launch this old boat next summer I'd like to install an inverter/charger (probably a Xantrax Freedom 1800). I've planned the inverter into my system, but I see a potential problem. Lightning. I'll be able to isolate the inverter when the boat is out on the water, so with any luck, if I'm struck I won't lose the inverter. The boat will spend a lot of time at the dock though. Since it will be connected to shore power I see the potential for voltage spikes and I'd hate to lose my inverter that way. I don't see any marine specific A/C surge supressors. Has anyone dealt with this issue. I suppose I could just go to Best Buy, pick something up there and configure it between the A/C main breaker and the inverter. I'm just fishin' for ideas on this issue. Thanks in Advance and Regards, MIA |
| If lightning strikes, you'll loose the inverter, no matter what you buy or construct to protect your equipment. Against lightning nearby and spikes in general you can use protection circuits based on Metal-oxide-varistors, like GMOV from General Electric. They are wired across the AC input lead directly after fuses. In case of severe over-voltage they start to conduct, creating a short circuit to immediately blow the fuses. For a 115 volts grid, types are used which start conducting around 150 volts but you can also use lower values like 125 volts. In the latter case the fuses will blow more often, like for example when someone switches a large motor on or off or a welding transformer. |
| Well, its not quite as simple as saying you will loose the inverter. A TVSS (transient voltage surge suppressor) of proper size will protect you from most strikes. Though, the price tag on the thing will make you wish you had never even heard of the thing. As CDK stated, an expensive (comparatively) solution would be MOV's, but will offer less protection in high load locations. Of course, considering you are on water (I'm going to guess salt) you might be able to get away with an indirect water ground. Since I don't know much about protection and water itself (outside what my code books tell me) I don't know if it would really work. But, in theory, running a copper plate down the hull across the water and tying it indirectly to your neutral should protect against far strikes (nothing direct or fairly close). If your feeling really lucky (or have a large boat that ISN'T METAL) you could run a strip of copper for the neutral and a strip of nickel for the hot line on opposing sides of the boat. Contrary to popular belief, most, water will not conduct electricity. In the case of a high voltage strike, the water would become conductive (due to ionization) and would surround the boat in a charged shield (don't touch the glowing boat kids). Then again, as I said, its only if you really REALLY feel lucky. Personally, don't worry about it much, get a small surge protection system and if you get a direct hit replace the inverter. - Jeremy |
| Thanks for the replys. I had a feeling that a small surge protector was the best I'd do in this situation, but thought I'd put this one out there to see if anyone else had an idea. MIA |
| Having suffered a direct lightning strike on a 54' cruising boat the only thing I could imagine protecting the boat would be not owning it. The through hull fittings were blown out of the boat, parts of the hull had boiled, glass was crystalized, and our entire electrical system was shot. In short, the boat was totaled and had it not been for the quick action of the marina it would have sank where it was. Heck the lead plates in the batteries melted. For a nearby strike a high quality surge protector is probably your best bet, and carry a little more insurance.
| There is strikes and there is spikes. You can not protect from a strike (lightening) thats boating. A spike ( surges) will usually be handled by a good charger. I would have thought you had a good suply in New york. Personally I would spllt the 2 and reduce the risk of blowing the whole thing. Chargers are easy to repair, inverters hardly ever repair. |
I believe that power at many marinas is not up to Home quality. |
| Thanks to everyone for the input. I will give serious thought to splitting the functions (separate inverter and charger). This seems like the most reasonable approach. Best regards, MIA |
| Missing, After a very quick peek at pricing it looks like a seperate charger and inverter will also save you a lot of money. Though the instilation might be a bit more time consuming.
| MOV's Quote:
BertKu |
| Lightning protection | Richard Woods | Multihulls | 4 | 08-10-2008 11:54 AM |
| Lightning Protection | DavidG | Boat Design | 1 | 07-20-2006 05:41 PM |
| Inverters | Jmarkley | Electrical Systems | 15 | 06-16-2005 02:39 AM |
| Cheap Inverters... | Sean Herron | Boat Design | 0 | 03-12-2005 08:05 PM |
| Lightning protection | Seattle lite | Sailboats | 7 | 10-14-2004 10:50 AM |
