Old 10-16-2008, 05:48 PM
Landlubber's Avatar
Rep: 1491 Posts: 2,449
Superyacht Wiring Schematic
Hi folks,
Does anyone have a generic wiring schematic suitable for a 120 foot private vessel. It is an exploration motoryacht we are building, and I would like the oportunity to compare my ideas with others that have already been built.
I have searched many site but found nothing suitable, only small recreational craft drawings.
Thanks
Old 10-17-2008, 12:14 PM
Fanie's Avatar
Fanie Fanie is offline
Fanie
Rep: 1930 Posts: 4,195
What is the base voltage ? Some use 12V, others prefer to run a generator all the time and use 230V.
Big drawing on paper of each layer. Mark all the groceries where you want to have them situated.
This way you can identify power hungry stuff and also plan the wiring distribution better.
I very much doubt if a 'standard' diagram exist, each would be unique for each boat, unless you are duplicating.
I also like the idea of different facets having their own power so that ie instruments have their own supply and is not affected by other electrical stuff. If a power problem emerges you can always backup from another system.
Sharing wiring between appliances is not always a good thing... you don't want the lights to konk out each time you winch the anchor in But then you know that.
Regards
Fanie
Water ! Just gimme water !
Old 10-17-2008, 05:11 PM
Landlubber's Avatar
Fanie,
I have built and wired many boats, so understand the basic principles well thanks.
What I am looking for is the schematics of a 120 foot boat that has recently been built so that i can compare my system to others on the market.
I plan to run a port and stb buss, bridging from each, similar to how they now do CAN-BUS systems, but without the controllers. I have also looked at Capi2 BUS, but am not yet convinced I want the vessel controlled by a computer.
We all have our own little quirks when it comes to total power sytems, i would like to see what others are doing in their little worlds as compared to mine.
The boat will be wired 240AC single phase, gensets will be 3 phase and power distribution to balance the phases and consumptions.
Shore power to be 3 phase at 30A each phase, so that where there is no 3 phase i can still pinch power on single phases.
12VDC will supply all other systems such as emergency lighting and low consumption night use syatems, starter to be decided yet as the main engine still has not been decided but looking at a MAK 20 series. (Air start).
Old 10-17-2008, 05:35 PM
Fanie's Avatar
Fanie
Best would probably be if you ask someone doing the same thing in person.
Interesting you mention the can bus without the processors.
Air start ? You pump the thing up with a bicycle pump to get the first kick... what happened to pull start... when I was your age...
Regards
Fanie
Old 10-17-2008, 06:23 PM
Landlubber's Avatar
I guess we can put a pull start on it, but the reduction ratio may make the rope about 5 metres long. Sort of run off with it eh
We will drop by one day and you can try it.
Old 10-24-2008, 04:33 AM
Landlubber's Avatar
No news yet, anyone have such a schematic?
Pleeeeeeeese
Old 10-24-2008, 07:43 AM
KnottyBuoyz's Avatar
KnottyBuoyz KnottyBuoyz is offline
Provocateur & Raconteur
Rep: 578 Posts: 604
You might want to contact this guy....
Alden Trull.... http://www.midcoast.com/~aft/index2.html
He's got some schematics on his site as examples of his work. I wouldn't count on any of them being what you need but I don't think there's any way you'll find anything better. His rates are reasonable and his work top rate (as far as I can see).
Yours Aye! Rick M/V She:Kon Blog
"It's not the boat "you built" until you've sworn at it, bled on it, sweated over it and cried beside it!" - I just made that up!
Old 10-25-2008, 04:36 AM
Landlubber's Avatar
Thanks KnottyBuoys, I have seen those before, basically what I have done myself already, i was hoping to find one suitable for a commercial 120 footer that I can verify what I have already done is in fact not too bad, I am trying to cover all my bases and not forget something.......
Old 10-25-2008, 06:46 AM
Rep: 578 Posts: 604
I think the complexity of an electrical system on a 120'er goes a bit beyond the capabilities/knowledge/experience of most of us here. Those that do that kind of work for a living don't normally turn their work loose on the Internet. You could post a dwg of your schematic here for review. Fresh eyes might spot something. I did that with my electrical plan (31' trawler) and we found quite a few things that needed to be corrected. Kinda like a "peer review" process.
Old 10-25-2008, 10:46 AM
Fanie's Avatar
Fanie
Well, as you probably noticed the electric / electronics of a boat is always suckling the hind teat. Haven't seen anyone put up new boat pictures and you look at the electronic circuits eh
Maybe one should do it, I bet it would be fun, get everyone off the hull shape and breaking waves stuff
Get them into amps and flashing leds How many knots does electricity flow at ?
Regards
Fanie
Old 10-25-2008, 11:53 AM
Rep: 578 Posts: 604
If we assume that electricity flows at the speed of light then it'd be...
161,874.977 knots (nm/hr)
Old 10-25-2008, 02:31 PM
Fanie's Avatar
Fanie
Sorry Lubby, I was going to make a point but as I posted a hailstorm hit us and power went off. Real fun, had to get the hail off the roof with toes freezing. Amazing how much trouble a bit of ice can cause. The direction it came from made a nice wall to guide the melting ice's water streight into the kitchen
Electronics / electrics is part of everything, I'm amazed that isn't discussed more. Normally it's just the guys wanting to run a household off his 60AH deep cycle and 3A solar
Regards
Fanie
Typical wiring schematic/diagram MCDUNK Electrical Systems 14 08-15-2010 12:11 PM
a marine wiring schematic ron phillips Electrical Systems 1 11-16-2005 04:31 PM
Battery Switching Schematic 67-LS1 Electrical Systems 6 12-28-2004 09:52 AM
Electrical Schematic help Craig_Hastie Boat Design 0 06-26-2004 07:30 PM
Trailer bearing schematic Spearfisher_Man Powerboats 7 08-07-2003 04:13 PM
