Old 03-27-2007, 07:08 AM
mikep mikep is offline
Short circuit
When the problem occurs I turn the ignition switch on to start the motor and the volt meter goes negative and the motor does nothing. To fix it I disconnect the battery and connect it back the motor starts. This happens without moving the motor and touching nothing else. It is like hitting a reset button. When the short occurs nothing works tilt are starter.
Old 03-27-2007, 10:15 AM
TerryKing's Avatar
TerryKing TerryKing is offline
On the Red Sea!
Rep: 278 Posts: 581
Location: King Abdullah University of Science & Technology - Near Jeddah, Saudi Arabia
"Short Circuit"
Mikep, I think you are seeing an "Open Circuit"! The circuit to the battery is "open" and the voltmeter reads Zero...
This sounds exactly like what happens in a car when there is a bad or corroded battery terminal / connection. Remove and check both battery terminals; make sure they (and the battery terminal surfaces) are clean and bright (scrape with a knife...) and put a thin coat of silicone grease or vaseline, or multipurpose grease over the connector surfaces and reassemble it. Get it tight! Also check the cable connections at the motor end; they can be loose or corroded.
Let us know what works!
Regards, Terry King ...On the Red Sea at KAUST
Perkins 4-236 cooling water circuit seaclusion Diesel Engines 0 01-11-2007 12:54 PM
Elan 36 short vs deep keel knuterikt Sailboats 8 08-13-2006 12:41 PM
Short article about using rhino CGN Software 0 08-19-2005 11:07 AM
outboard not short enough! bish Boatbuilding 0 06-07-2004 06:57 AM
Outboards and Short Range Offshore JPigott Boat Design 5 01-03-2003 09:40 PM
