Old 04-28-2006, 12:36 AM
ElectricCat ElectricCat is offline
Sea Water Cooled Ice Maker and guts for a built-in freezer?
I'm involved in a catamaran project and have designed electrical system for this boat. The boat has electric propulsion and plenty of excess electricity which will be used to power various appliances.
One of the appliances is an 20,000BTU A/C chiller which comes as sea water cooled.
I like the idea of not having hot air being blown into the boat and was wondering if someone knows a brand of a small ice maker (such as popeluar Raritan) but water, rather than air cooled. Or perfhaps we could put one together ourseleves in a custom fiberglass box if the part kit was available?
Also looking for a source of similar (water cooled) cooler part kit to fit inside a custom freezer box (approx 4 cubic ft).
They can be 120VAC powered.
Any hints will be appreciated. Thanks
Michal, www.electriccatamaran.com
Old 04-28-2006, 12:54 AM
JPC JPC is offline
Rep: 20 Posts: 90
I don't have any specific recommendation, but here is one source that might get you started:
http://www.seafrost.com/
Best regards,
JPC
Old 04-28-2006, 07:51 PM
Rep: 1397 Posts: 7,216
If the chiller is sea water cooled, where does the hot air come from?
Old 05-02-2006, 08:20 AM
TuckSail TuckSail is offline
Mechanical Engineer
Rep: 10 Posts: 15
Eskimo Ice makes an Ice maker that is raw water cooled. It produces up to 600lbs of freshwater ice per day
Old 05-26-2006, 04:40 AM
Vikendios Vikendios is offline
Rep: 10 Posts: 13
Keel coolers for refrigerant gas are much better.
IMHO any refrigeration system that does not use keel coolers is now obsolete. These do away with the whole mess of circulating water in the boat. Check www.veco.net Unfortunately they are still not available in sizes big enough to use with Air Conditioners, but that should soon come.
Old 05-29-2006, 05:45 PM
How do you propose to install keel coolers in fiberglass boats?
Old 06-01-2006, 01:52 PM
Tim B Tim B is offline
Rep: 763 Posts: 1,384
Why not build a box around the fridge's cooling system and pump water through that. It's only a heat-exchanger!!
Tim B.
Old 06-10-2006, 10:56 AM
bazza bazza is offline
Rep: 10 Posts: 25
the u,line icemakers are just a freezer with an icemaker unit screwed to the evaperator. just conect up a thermostat and a water solonoid valve and you have instant ice from your freezer. the whole icemaker unit as a replacement is only a couple of hundred buck.
bazza.
Built in ice-box foam....what's best? paularey Fiberglass and Composite Boat Building 14 07-26-2006 10:14 PM
water cooled exhausts, why ? saeble Propulsion 11 12-26-2005 03:49 AM
Water cooled stuffing box Graben Propulsion 2 12-08-2005 11:33 PM
NISSAN water cooled exhaust system ? cyclops Propulsion 1 12-02-2005 01:11 AM
Water Cooled Exhaust Manifolds CPC Powerboats 4 03-30-2004 08:45 PM
