| Rule automatic bilge pumps. Explorer Marine build fast RIBs in Devon UK and we have used Rule pumps for several years. We have recently been finding that the RULE 25 S-6 pumps have a very high failure rate. Almost half the pumps we have fitted this year have failed. Most fail within three weeks after launching and fail to no function or fail to continuously running which flattens the battery. Do any of you - RULE pumps are made in the US - have any experience of these problems or any ideas for a more reliable automatic bilge pump for small open boats? |
| I've had great luck with Rule pumps, they're all I use. Attwood pumps are the ones to avoid at all costs. Perhaps the particular model you're using is a bad design. I'd try a different model pump and see what happens. Sounds like the float is what's failing. Is it internal?
__________________ Craig Cavanaugh Silver King Custom Marine No shoes, no shirt, no problem! |
| Rule Bilge pumps Thanks for that, but this model of Rule pump is entirely electronic with no float. The pump "cycles" every 2,5 minutes and tests by current flow whether there is water there. If there is it continues, if not it stops after about 2 seconds. These used to work very well, but recently the new three wire design has let us down badly. Hugh Mattos Explorer Marine Devon UK |
| I have old 3 wire units. Perfect. Looks like a bad batch from somewhere. Are you telling corporate how bad the units are? I always call corporate if I get 2 bad units in a row. |
| Just to clarify the latest... Rule in the UK have stated that they had a problem with some electronic units in the Rule 25S- 6 pumps. they have offered to replace the old failed units. |
| A lot of good companies are getting crap names as they have the Chinese build their products. Life goes on. |
| Yes, have seen regularly automatic models not shutting off. For the best float switch out there look for the Ultra Safety Switch, made in Fla. |
| 12v Bilge pump timer/delayed shut-off...? | paularey | Sailboats | 5 | 11-04-2005 03:39 PM |
| bilge Pump monitor | odyssey11 | Marketplace | 0 | 10-24-2005 07:05 AM |
| Bilge pumps flow rate | Alik | Boat Design | 2 | 10-06-2004 06:56 AM |
| Bilge pumps | redcoopers | Sailboats | 4 | 09-19-2004 06:36 AM |
| electricity-free bilge pumps | whitecj | Boat Design | 3 | 11-10-2003 08:38 AM |
