Old 03-11-2012, 01:27 PM
missinginaction missinginaction is offline
Rep: 451 Posts: 448
ring connectors and multiple wires
I'm laying out the wiring for my helm instruments. The old wiring just looked to me like a "birds nest". Wires going everywhere.
I noticed on the old helm that every single wire that connected to each gauge had it's own ring terminal. This caused many of the studs to have 2-4 ring terminals stacked.
I'm wondering weather it's proper wiring technique to combine 2 separate wires or even more into a single ring connector provided the ring connector is the proper size. For instance if we have 2 AWG#16 wires is it acceptable to place both wires into an AWG 10-12 sized ring terminal? It would seem that by doing this I could neaten up the panel wiring quite a bit. If I'm making up a grounding wiring "harness" for a gauge set running all the grounds in series this technique makes for a much neater installation.
Any thoughts?
MIA
Old 03-11-2012, 01:29 PM
gonzo gonzo is online now
Rep: 1743 Posts: 8,439
Yes, that is the preferred way of doing a harness. You can make a jumper for all the power feeds and one for all the grounds.
Old 03-11-2012, 02:40 PM
keysdisease's Avatar
keysdisease keysdisease is offline
Rep: 285 Posts: 612
There is an ABYC standard for how many connectors are acceptable per stud. I believe it may even be a different number per wire size.
The below standard is for battery studs, I believe there are other standards for buss bars, etc.
ABYC (E-11.16.4.1.11)
One additional related requirement limits the number of conductors that can be secured to a battery stud to four. Multiple connections can hinder good electrical contact and more than four connections could result in insufficient engagement area between the nut or lug and the stud. Again, excessive heat buildup could result.
Bonus: Here's the recommended color codes:
http://www.acbsphl.org/Tips_and_hints/ABYC_Wiring.htm
Steve
Old 03-11-2012, 03:12 PM
Rep: 451 Posts: 448
Thanks for the replies guys. I thought that this technique would be OK Gonzo.
I understand that there is a limit or four connectors on a battery stud, my question here though was limited to wiring around the helm with light gauge wires.
Regards,
MIA
Old 03-11-2012, 03:32 PM
The more connectors you stack, the worse it gets. At the battery, that means high temperatures and even melted battery posts. On gauges it is not as dangerous, but still bad practice.
Old 03-12-2012, 03:47 AM
CDK's Avatar
CDK CDK is offline
retired engineer
Rep: 1677 Posts: 2,713
On the gauges you can simplify the wiring by making a daisy chain for all ground terminals by crimping two wires in a connector. The ground terminals are for illumination only.
For the positive side there may be 2 terminals on a gauge, one for illumination and one for the gauge itself. These can also be bridged and daisy chained between gauges, greatly reducing the wire count. Only an ammeter must be wired separately.
cogito, ergo sum (Descartes' credo)
Old 03-12-2012, 05:51 AM
Rep: 451 Posts: 448
Good to hear from you CDK. That's precisely what I ended up doing. I had a pleasant time making up some harnesses for the ground circuit and the lighting power circuit on my workbench. Having these harnesses pre-made will simplify the final installation when I install the gauge panels in the boat.
Hope all is going well for you,
MIA
Old 03-18-2012, 07:04 AM
Rep: 451 Posts: 448
It ended up like this.
ring connectors and multiple wires-img_0161-1-.jpg  ring connectors and multiple wires-img_0168-1-.jpg
Two spreader lights from a single pair of wires ayates Electrical Systems 11 12-14-2011 01:35 AM
tieing a line to a ring buoy with 4 slotted holes in ring and no line now sdowney717 Open Discussion: All Things Boats & Boating 22 07-10-2011 09:58 AM
Pontoons and Connectors nikezz Boat Design 8 11-19-2010 12:45 AM
multiple sails rlawler Multihulls 6 10-15-2010 01:23 AM
