Old 09-18-2011, 03:45 AM
Rep: 1729 Posts: 2,462
Replacment Rectifier for MIG Welder
I have a 250 Amp single pahase Mig Welder which had a diode short circuit in the rectifier.
The replacement rectifier was available but expensive and I didn’t really trust it already having had one die.
Stud mount power diodes were very expensive but after a little research I simply bought a few 50Amp diode rectifier blocks in alloy cases (CM5006) added a few for a large FOS and wired them all in parallel.. I mounted them on a common heasink for close thermal coupling and kept the lead lengths the same and it works very well.
The professional welder who was using my MIG machine thought it had a smoother arc than before it failed.
If anyone wants to produce a high current cheap rectifier for any purpose the diode blocks cost me around $8 each for 10 and I used 8 for good measure because I didn’t know how well it would work.
That gives a 100% duty cycle of 400A and they don’t even get warm at 180 Amps continuous , if I did it again I’d just divide the current by 50 and round up ( 5 blocks for 250Amps ) the rectifiers are already overrated and handle surge current an order of magnitude higher for short periods.
I'd also use crimp connectors too rather than soldering.
Mike Johns.
Aluminium welding(mig), welder qualification Kiev Fernandes Metal Boat Building 1 11-28-2009 07:48 AM
Can you do this with a mig welder shakey78 Boat Design 3 09-23-2009 10:30 PM
Lincoln 180C MIG Welder cahudson42 Metal Boat Building 18 12-13-2007 06:16 PM
burning up my rectifier codyjsmith Outboards 5 03-27-2007 04:09 PM
Duratec Replacment Oldshoe Materials 2 12-19-2006 12:12 AM
