Old 03-17-2008, 01:29 PM
GWB GWB is offline
Rep: 10 Posts: 67
New installation
I have what is probably a dumb question about a new electrical installation in a sailboat.
There will be 2 batteries (house and starting) an alternator, a 1 or 2 or both battery selector switch and a battery charger.
What would be used for wire size and do I need to put diodes in the wiring?
Thanks for any help
Old 03-18-2008, 07:53 AM
KnottyBuoyz's Avatar
KnottyBuoyz KnottyBuoyz is offline
Provocateur & Raconteur
Rep: 578 Posts: 604
Wire size will be dependant upon the load carried by the conductor and the length of the circuit. You will not need diodes in the wiring. If you want to charge both batteries from a single source (alternator) I'd suggest the Blue Sea "Add a Battery" set which consists of a switch and battery combiner.
http://bluesea.com/products/7650
This makes it simple and goof proof.
To determine the size of the wire you'll need you can use either a "wire sizing" chart (published on the Internet in multiple places) or this "Wire Sizer" program from Aldun Trull
Just remember the length of the run includes both sides of the circuit from battery to load and ground back to battery. There's also the BoatDesigns Wiki with loads of info.
http://www.boatdesign.net/wiki/Electrical_systems
Good luck.
Yours Aye! Rick M/V She:Kon Blog
"It's not the boat "you built" until you've sworn at it, bled on it, sweated over it and cried beside it!" - I just made that up!
Old 03-24-2008, 10:48 AM
GWB GWB is offline
Rep: 10 Posts: 67
Thanks for that KB.
Do you perhaps have a wiring diagram that I could reference?
Old 03-24-2008, 01:05 PM
Rep: 578 Posts: 604
Originally Posted by GWB View Post
Thanks for that KB.
If you look on the "product documents" tab on the Blue Sea site you should find everything you need.
outboard installation drawing ars-technica Boat Design 3 11-11-2006 05:47 PM
Sterndrive installation Danielsan Sterndrives 14 04-27-2006 08:01 PM
generator installation Wild Bill Electrical Systems 0 02-16-2006 08:53 PM
Knotmeter installation Danny Sailboats 8 05-18-2005 12:34 AM
plywood deck installation CaptinJD Wooden Boat Building and Restoration 10 09-22-2004 11:02 PM
