Old 08-27-2008, 02:36 AM
Archie1979 Archie1979 is offline
Rep: 36 Posts: 57
New Boat build Power installation
Hi all,
I am just starting to plan my new power installtion for my boat. I have started by selecting the battery for the starter and things what I do need is information on what needs to be connected to the starter battery. There will be the starting circuit and most likely a 24v system so 2 more large batts around 200ah each
So Far :-
Starting Batt (X-Cell 12V 75ah AGM 750cca)
on this circuit will be
- Starter Motor
- Eng Instruments approx 6A
- Bilge Pump 3.2A 5A fuse
- Bilge Blower 2.7A 3A fuse
- Gas detector 2A fuse
Is anything else required on this circuit.
The battery banks will be connected to the alt by the blueseas 120A automatic charging relay with the Dual circuit battery switch all Blue seas.
Thats all i have so far.
Does anyone have experience in designing there own system and does this sound sufficient so far. I have been reading the Marine Electrcial Electronics Bible by John C Payne.
Any thoughts help is appreciated
Steve
Old 08-27-2008, 08:04 AM
KnottyBuoyz's Avatar
KnottyBuoyz KnottyBuoyz is offline
Provocateur & Raconteur
Rep: 578 Posts: 604
Hey Steve
That's pretty much got it right. I'd move the bilge pump to your house bank as it's probably much larger in capacity than your starting battery. My personal preference is to keep only the absolute essentials to start the boat on the starting battery. A bilge pump isn't essential to starting the boat. I do use two bilge pumps, a small pump running off the house bank that pretty much handles all the pumping duties on my boat and a large de-watering pump with a solid state automatic switch that runs off the house bank. This second pump sits a bit higher in the bilge than the first and will kick in if the first one fails.
There's a thread on here somewhere with my preliminary electrical design for our trawler but I can't put my finger on it and there's the Electrical Wiki too.
http://www.boatdesign.net/wiki/Electrical_systems
I've switched out a battery isolator this year in favor of the BlueSea ACR, good choice and it works exactly as advertised.
Yours Aye! Rick M/V She:Kon Blog
"It's not the boat "you built" until you've sworn at it, bled on it, sweated over it and cried beside it!" - I just made that up!
Old 08-28-2008, 03:27 AM
Rep: 36 Posts: 57
Quick one what software did you use to draw up your wiring diagram, I am just using a pen and paper at the moment.
Cheers
Archie
Old 08-28-2008, 08:01 AM
Rep: 578 Posts: 604
Cheers
Archie
Microsoft Visio Professional. I've also used Autocad on occasion.
Old 08-28-2008, 10:29 PM
Rep: 36 Posts: 57
Where did you get yourelectrcial symbols from or did you draw them in
Old 08-29-2008, 07:40 AM
Rep: 578 Posts: 604
There are a lot of them in the Visio templates, I think I got the Autocad ones form some engineering drawings I have for the 47' MLB's. Other than that I drew the rest. The electrical panel I had to redraw from scratch. Some mfgrs offer drawings of their equipment that can be imported or redrawn.
Old 08-29-2008, 05:06 PM
Rep: 36 Posts: 57
Thanks for the info, I guess i will be starting my diagrams this weekend.
New installation GWB Electrical Systems 3 03-24-2008 01:05 PM
Wanting to build a Power 20'-22' TRI ncstriper Multihulls 0 03-04-2008 08:07 AM
Where would you build a boat in the UK? mattnedgus Open Discussion: All Things Boats & Boating 30 09-18-2007 07:30 AM
Build my first boat mirsat Fiberglass and Composite Boat Building 3 08-27-2007 09:23 AM
my human power boat build by myself lijunhaoORaj Boatbuilding 3 06-22-2005 10:07 AM
