Old 05-12-2008, 05:45 PM
guest200901
multi-hull wiring
hi everyone.......!
would anyone have a basic wiring diagram for a 46 cat ?
what panel with extras should i use ?
Old 05-12-2008, 07:12 PM
masalai masalai is online now
masalai
Rep: 1630 Posts: 7,322
Not in USA (an Australian Coy) but this may give a general understanding http://www.outbackmarine.com.au/Mast...l.asp?LineID=1 For the low volt circuits (12 or 24 volt) I would look to fusing each task at the bus-bar and where you would switch that item on or off... Do the inspection and make your choices...
Outback marine have heaps of online help and ideas using their products (240v AC is NOT suitable for USA)
Try to be helpful... The trouble with people is to realise and remember that there are at least two sides for every story...
A woman's breasts, one is not enough, - two may be just right, - but dreaming of 3 is a pleasant fantasy...
Old 05-13-2008, 09:06 PM
guest200901
thanks
thanks for the info 1
Old 10-22-2008, 10:22 PM
BigCat's Avatar
BigCat BigCat is offline
Rep: 27 Posts: 72
Make sure to ground the negative ground to a shared plate on the outside of the hull underwater-do this with all systems, even if they have different voltages. If you use lightning grounding, that goes to the plate, too.
Old 10-24-2008, 08:03 PM
mikereed100 mikereed100 is offline
Rep: 30 Posts: 82
Kevin Jeffrey wrote a 3 part series of articles for Multihulls Magazine a while back in which he described wiring for multihulls, from simple to complex, including sample diagrams. I will try to find out which issues they were in.
Mike
Old 10-24-2008, 10:03 PM
Ike's Avatar
Ike Ike is offline
Rep: 1256 Posts: 1,317
first take a look at http://newboatbuilders.com/pages/elect.html Near the bottom of the page are some sample wiring diagrams. One is for an auxiliary sail boat.
Ike
New Boatbuilders Home Page
Boat Builder News Blog
My Boating Safety Blog
Old 10-24-2008, 10:13 PM
Ike's Avatar
Ike Ike is offline
Then get one of the following books. I recommend Nigel Calders
Boatowner's Mechanical and Electrical Manual, by Nigel Calder
The 12 Volt Bible, by Miner K Brotherton and Ed Sherman
Boating Magazine's Powerboater's Guide to Electrical Systems by Ed Sherman
Sailboat Electrical Systems, Don Casey, 1999 International Marine
Boatowner's Illustrated Handbook of Wiring, by Charlie Wing
Your Boat's Electrical System, by Conrad Miller and E. S. Maloney
Managing 12 Volts, Harold Barre 1997 Summer Breeze Publishing
Ike
multi hull houseboat pontoon flyer Fiberglass and Composite Boat Building 0 07-18-2007 05:23 PM
CLP; mono-hull vs multi-hull jibbernaught Boat Design 0 06-05-2007 04:07 PM
Ulimate Multi-Hull Wynand N Boat Design 3 12-05-2004 05:49 AM
Multi Hull boats J. Olson Boatbuilding 5 08-28-2004 08:40 AM
Multi-Hull Boats J. Olson Powerboats 2 08-05-2001 05:15 PM
