Old 09-19-2011, 05:28 PM
tegaaskfornero tegaaskfornero is offline
Rep: 10 Posts: 2
Modefying the temprature of water
how many volts can i use to heat up water to 115 degres in like 5-10 mins and wht resistance i need? please help me out. u can also reply to my mail tegaaskfornero@yahoo.com
Old 09-19-2011, 06:33 PM
Rep: 10 Posts: 2
what about the amount of volts i need to heat up a water to 100 degrees in 5-10mins and wht resistance do i need?
Old 09-19-2011, 07:24 PM
Boat Design Net Moderator Boat Design Net Moderator is offline
Moderator
Rep: 647 Posts: 184
tegaaskfornero, I've removed 4 duplicate posts and split this into its own thread as it gets confusing when the same exact question is crossposted in a number of different threads in duplicate. It's best to pick one "best location" for a question and let the discussion happen in one thread. Thanks for your understanding.
Please be polite to all other members. Please respect those who take their time to give advice freely. And please keep threads on topic. Forum Rules
Old 09-21-2011, 08:35 PM
Rep: 1493 Posts: 7,447
You can use any voltage you want. The wattage will depend on the amount of water you want to heat. Also, on the insulation qualities of the container, whether the water is being stirred too.
Old 11-05-2011, 10:37 PM
jamesgyore's Avatar
jamesgyore jamesgyore is offline
Rep: 136 Posts: 64
I had some questions along to same lines as you have... I think.
I wanted the luxury of hot water and spent several days googling the subject.
I'm not keen on having gas on board, so I went on the hunt for a 240v/12v electric hot water heater.
This might be what your looking for:
http://ausj.com.au/Duetto-10.htm
Regards.
Old 11-05-2011, 11:55 PM
Frosty's Avatar
Frosty Frosty is offline
Rep: 1693 Posts: 5,866
In Europe a water heat called a hand wash is 3KW the small instant heater above a sink.
A shower that instantly heats water is 6 or maybe 7KW and the wiring needs serious consideration and fusing sperately from all other circuits.
A 2/3 liter kettle will be 800w to 1.2 KW.
In the tropics where water enting the heater is rarely less than 25 degrees it will heat for a shower with 3..4KW.
6KW on a boat would need a good 8kw geny.
Old 11-06-2011, 04:36 AM
daiquiri's Avatar
daiquiri daiquiri is offline
Engineering and Design
Rep: 2574 Posts: 2,731
The power necessary to heat 1 liter of water from 15 to 115 °C in 5 min time is 1.4 kW. If the time is stretched to 10 mins then the power is halved - 0.7 kW. That's for 1 liter, so you need to multiply these powers by the actual capacity of your boiler. For example, a 100 lt boiler will require 140 kW.
Bear in mind that above 100 °C you are talking about superheated water, which requires working pressures above the atmospheric. For 115 °C, the pressure inside the boiler, piping, valves etc. will be around 1.7 atm (or bar). You have to make sure that all the components in your plant are certified for both these pressures and temperatures.
Cheers
Normal operating temprature for Mercruiser 188/Ford 302 holorinhal Sterndrives 6 05-26-2009 02:13 AM
salt water vs fresh water bouyancy in boat plans blackdaisies Boat Design 8 04-30-2009 08:00 PM
Osmosis - Fresh Water vs Salt Water andy_uk Fiberglass and Composite Boat Building 0 05-21-2008 02:40 AM
No water in oil pan, But water in oil filter? midtower Gas Engines 14 03-19-2005 05:43 PM
Fuel, water, black water tank construction kudu Boat Design 12 07-25-2003 06:54 PM
