Old 06-19-2007, 10:02 AM
discodano discodano is offline
Minn Kota Trolling motor won't turn left
I have a Minn Kota Powerdrive 36 lb. version 1, model MKJF-0223162 that I have been working on. I replaced the lower motor to get it working, and the motor that turns it left and right, servo type, was seized up, I got it free, but am now having trouble getting it to turn in the left direction. I noticed that there is what seems to be some sort of diode jumper from one lead to the other on the servo motor. I have switched the wires on the leads to make sure that it is not a problem with the motor itself and have replaced the foot pedal with a new one, so both of those are not the issue. I believe it to be a wiring issue, as I am not getting any voltage coming to the motor when the left pedal is pressed. I think this diode jumper thing is the key, any ideas? the print out on the diode is 7K180.
Old 08-17-2007, 05:48 AM
wellmanj wellmanj is offline
JW
diode
is the diode bad? replace it anyway. they can't be too much $.
Jon Boat: Mounting a Trolling Motor? Ronnie Hilton Boat Design 3 04-21-2007 10:33 AM
Bayliner 175 bow trolling motor, how? boatmen Powerboats 3 01-24-2007 08:52 AM
Best way to suspend and turn a boat mtnrat Boat Design 9 09-08-2006 04:00 PM
Trolling motor for aux power LP Sailboats 23 04-27-2006 12:10 PM
1998 Four Winns Lack Of Power During Left Turn KENSINGTONAUTO1 Propulsion 2 07-06-2005 05:10 PM
