Old 07-08-2007, 07:47 AM
m.s.j m.s.j is offline
Rep: 10 Posts: 7
Measuring of generator winding resistance
Recently I participated in a generator electrical test program. Measuring of Stator winding resistane is also of the mentioned tests.
The recommended test procedure by manufacturer to calculate winding resistance is wattmeter method. In this method, one 50HZ power supply is applied to the three phases of stator winding which is separated from other sections. In this condition electrical current of each phase ( I ) and active power consumption of three phases ( W ) are measured by suitable measuring instruments. Then resistance of each phase ( R ) is calculated as following relation:
W = RI2
As you know, there are many ways to measure active power in three phase symmetrical circuits.One, two and three-wattmeter methods may be used but in this case, generator manufacturer only recommended "two-wattmeter method" and high accuracy wattmeter for this measurement.
How can you explain the reasons of manufacturer choice? Why the two-wattmeter method is the best choice to reduce measurement errors in this case?
Old 07-08-2007, 07:59 AM
Frosty's Avatar
Frosty Frosty is offline
Rep: 1528 Posts: 5,519
This question along with your other question about transformers would fare well on an electrical forum, wouldnt you think?
Most paticipants on this forum the boatdesign.net have interests in the boat industry and are interested in boats in generall.
You may get a reply -one can always hope but some how I think you already know the answer and are infact submitting a riddle?
Old 07-09-2007, 02:30 AM
TerryKing's Avatar
TerryKing TerryKing is offline
On the Red Sea!
Rep: 278 Posts: 581
Location: King Abdullah University of Science & Technology - Near Jeddah, Saudi Arabia
Answers...
Sounds like a HomeWork problem to me...
Regards, Terry King ...On the Red Sea at KAUST
Old 07-10-2007, 02:01 AM
Rep: 10 Posts: 7
Yes, I know the answer of my questions (at least personally), but as you know each question can be had several correct answers and there are some things for thinking in each new answer. However this activity is a mental try to share our knowledge, experience and practical information in electrical engineering. I hope you participate in this unison that has been constructed for science propagation.
My watchword is "THINKING IS ENJOYABLE THEN THINK ABOUT YOUR SURROUNDING THINGS AND OTHER THOUGHT PRODUCTS"
Thank you very much
Marine generator BustedKnuckle Electrical Systems 11 11-23-2007 09:01 AM
Standards for measuring waterline length Randerso Boat Design 7 11-05-2006 11:58 AM
measuring outboard prop hp? kenfyoozed Boat Design 4 03-18-2005 06:00 PM
Measuring odd shapes, duluthboats Press Releases 2 08-11-2004 04:45 PM
Measuring a hull duluthboats Open Discussion: All Things Boats & Boating 6 11-07-2002 02:42 AM
