Old 04-24-2010, 07:49 AM
missinginaction missinginaction is offline
Rep: 417 Posts: 336
That's what I needed to know. Based on the size of my boat and the loads expected 12 volts makes more sense.
Thanks Terry and CDK.
MIA
Old 06-22-2011, 04:18 AM
frasco frasco is offline
Rep: 10 Posts: 27
I'm in the progress of building a sailboat interior and thinking about using (chargeable) battery powered LED lamps (bike- or headlamps maybe) for interior lighting. They could also easily be removed and used as flashlights. I'd also run as much other electronics with rechargeable batteries (GPS etc). The advantages would be less wiring and a more flexible system. An obvious downside would be the constant switching of batteries and charging them.
Thoughts about other advantages/disadvantages?
Old 07-14-2011, 12:53 AM
mitiempo mitiempo is offline
Rep: 14 Posts: 18
frasco
Sounds like a pain to me to always be charging light fixtures.
On a small boat without an electrical system, like a 18' weekender it makes sense. But on a larger boat with a 12 volt system I would wire them into the panel.
LED Interior lighting info needed. Craig_Hastie Materials 7 05-02-2008 04:52 PM
Battery operated LED lighting Willallison Boat Design 13 04-19-2008 01:38 AM
Highly Efficient LED Accent Lighting rvaid Electrical Systems 7 01-25-2005 12:38 AM
LED Lighting |Boats & Yachts OFFERED RichardR Marketplace 0 08-17-2004 09:03 AM
SolidStateRacing introduces Ultra-High power LED lighting modules for Marine William James Marketplace 2 05-13-2004 04:19 PM
