Old 07-09-2006, 01:16 PM
tacomatrd00 tacomatrd00 is offline
Rep: 10 Posts: 4
ignition switch 6 prong to 4 prong
I have a 67 mercury outboard and the contacts in the ignition went bad so I was going to replace it with an aftermarket switch but the new switch only have 4 prongs and not 6 light oem switch. I have the wiring diagram but it just tells what colors went to what prong, I need to know what goes where HELP PLEASE!
Old 07-09-2006, 09:55 PM
Rep: 1493 Posts: 7,447
The 6 prong switch is probably for a push choke. If you don't put the original type, it will be very hard to start. Also, it is impossible to give you instructions to hook up a mystery switch. Can you post a schematics of the switch?
merc 3.0 conventional ignition - no spark smitty Electrical Systems 1 06-19-2006 12:06 AM
Ignition Switch Wiring???? bgull2 Outboards 0 05-29-2006 03:14 PM
AC Auto Transfer Switch bcervelo Electrical Systems 1 05-08-2006 11:06 PM
Ignition lanyard Thunderhead19 Powerboats 7 08-11-2005 02:19 PM
yamaha key switch question wd jones Powerboats 2 04-06-2005 09:43 PM
