Old 03-15-2009, 06:24 AM
dermo dermo is offline
Rep: 11 Posts: 4
How To Isolate A Alternater Question
Can anyone tell me how to isolate a truck alternater,or can it be done the alternater is 90amp i think its a lucas
Old 03-15-2009, 07:15 AM
Jack Daniels Eq's Avatar
Jack Daniels Eq Jack Daniels Eq is offline
Shockwave
Rep: 11 Posts: 50
Dont unnastunt the kwestun Paddy
Isnt that the 17th?!
BR>Jack
Old 03-17-2009, 05:33 AM
TedZ TedZ is offline
Rep: 11 Posts: 23
Isolate it because it is putting "noise" on your DC components? There is a capacitor on the alternator that does a great deal of that. Replace it as a starter. If you want a filter and you have an idea of the speed of the alternator (not the engine, the speed after pulleys) you can improve on the filtering using a band stop filter if you have the frequency range of the interference. (Speed range of alternator times 6 usually for six lobes on rotor) They are trivial, $5 to make...lots of sites with design programs.
If you are talking about switching it off when running as "isolation" don't.
Ted
Old 03-17-2009, 06:23 AM
Rep: 11 Posts: 4
what am basicly trying to do is turn a truck alt into a marine one,
i was told i could put non return diodes into the alt.
i have'nt got much experience in this area?
Old 03-17-2009, 06:38 AM
Rep: 11 Posts: 23
The reason marine alternators are more expensive is because of their robust design. http://www.boatelectric.com/alternat.htm Although Baldor doesn't mention it there are explosion proof aspects to the alternators that can be quite important depending on your ER environment. If you can mount it and if you can use a sufficient V-belt to drive it, the truck alternator will work without modification for awhile. I would not do it but it is up to you considering the points made in the article. If you have a gas engine, don't use it. Insurance if you make that modification??
Ted
Old 03-17-2009, 06:42 AM
Rep: 11 Posts: 23
Sorry, Balmar not Baldor. Baldor makes electric motors. The link is correct and worth reading.
Ted
Old 03-25-2009, 08:00 AM
pistnbroke's Avatar
I try
Rep: 387 Posts: 1,269
the only time I have seen someone want to isolate an alternator is if they dont want it negative earth .....this is done with nylon bushes on the mounting ...so if you tell us what you are trying to do I can advise ....
How to change the Alternater belt? Art Outboards 4 09-15-2006 10:39 AM
