Old 05-11-2011, 08:52 PM
geste geste is offline
Rep: 10 Posts: 5
hardware store bonding bar
Y'all,
First post. And not building a boat but working on a 1975-vintage fixer. I couldn't find the "fixer/electrical" forum.
I have put about 30 separate projects in my notebook including replacing *all* AC wiring and about half of the DC wiring.
I would like to improve on some of the existing bonding and went looking for a nice copper *something* to tie in through-hulls and a zillion other things.
I was at a local hardware store and it hit me: Why not take that 40-dollar, 10-foot-long, 1-inch-diameter, schedule-K copper water pipe, then mash it flat between some 2by4s, heat it up and fill the gaps/end with solder, then tap it as needed along its length to tie bonding connections in.
I ask because my last boat had a "factory" bonding strap that seemed pretty wimpy and I wonder if this would be an improvement (without breaking the bank).
Cheers,
Jim
Old 05-11-2011, 09:07 PM
Rep: 1493 Posts: 7,447
Unless you need lightning protection a copper wire will work fine.
Old 05-12-2011, 07:46 PM
Rep: 10 Posts: 5
Bonding bar
I had in mind a *little* overkill. My last boat had a length of that perforated copper pipe-hanging strap and it just sort of slid around the bilges. So I was thinking of something maybe a bit more rigid, a strap/bar that I could maybe even secure to some non-conductive standoffs -- elevate it in what little bilge there is in the new boat -- and be able to see connections plainly.
So it sounds like not necessary, but no reason it wouldn't work...?
Jim
Old 05-13-2011, 06:51 AM
hoytedow's Avatar
hoytedow hoytedow is offline
Resistor
Rep: 1871 Posts: 3,357
Welcome, geste.
Hoyt
Old 05-14-2011, 08:55 AM
You can buy copper strap for less than the cost of pipe. It is commonly used for grounding.
Old 05-14-2011, 01:14 PM
hoytedow's Avatar
Resistor
Being braided, the strap is less prone to fracture/failure.
Hoyt
Old 05-14-2011, 06:59 PM
Rep: 10 Posts: 5
Braided strap
hoytedow,
Now braided vs. solid I can identify with. Got a pointer for some braided strap?
Some of the appeal of using some squashed pipe is to have less surface area to oxidize (over a bunch of naked copper strands), but I have to admit that the general idea of more flexible stranded/braided is compelling.
I have more noob questions in the queue.
Jim
Old 05-14-2011, 07:00 PM
Rep: 10 Posts: 5
Thanks
Originally Posted by hoytedow View Post
Welcome, geste.
Oh, and thanks!
Jim
Old 05-15-2011, 12:39 PM
hoytedow's Avatar
Resistor
Originally Posted by geste View Post
hoytedow,
Jim
Spray or brush liquid rubber on the strap and only expose that part where connections are made and coat those too.
Hoyt
Old 06-10-2011, 12:07 AM
Mark Cat Mark Cat is offline
Rep: 34 Posts: 73
Gonzo once again has very helpful hints, and not sure how many noticed, focused in on the key area, Lightning protection.
If you go through a complete design, Lightning protection to grounding to Communications to bonding to corrosion to safety to shore power, and then look at the underlying driver for below the water line conduction, and then iterate the design tradeoffs a view times.
You will fine that the requirement for lighting protection is the driver, or should I say instigator, for a whole chain of design events which then dictate the approach to grounding, bonding and all the other stuff I listed above.
ABYC should be referenced for the details concerning the interrelation of all of the above.
Mark
4-bar linkage question sigurd Propulsion 6 02-13-2011 06:53 AM
Where to Store Gasoline on a Deisel Powered Boat? Michael W Boat Design 15 07-13-2009 02:36 PM
Online Store is Finally UP and Running gcmdistributor Boat Design 0 02-03-2009 09:05 AM
Where to start? where to store? lantanatx Wooden Boat Building and Restoration 3 09-11-2006 05:54 PM
shower store raymond Fiberglass and Composite Boat Building 2 01-13-2006 03:57 PM
