Old 01-09-2012, 03:23 AM
xlr8 xlr8 is offline
Rep: 10 Posts: 14
Generator for catamaran
I am in process of shifting Onan 9kw generator from engine room to bridge where height above LWL is 1500mm. Do I need a extra feed pump for raw water?
Old 01-09-2012, 05:41 PM
Poida Poida is offline
Rep: 395 Posts: 1,072
Nobody can give you any information based on they details you have provided.
You need the flow rate required through the generator, possibly from their website.
You need the specifications of the pump, which will be in the form of a graph which shows the flow rate in reference to head.
Or get the flow rate required for the gen set.
Then set up a hose up to the 1500mm height required and check the rate of filling up a bucket.
Poida
Old 01-10-2012, 02:27 AM
CDK's Avatar
CDK CDK is offline
retired engineer
Rep: 1425 Posts: 2,252
Keep the water hose well above the raw water pump. This ensures that the impeller will not run dry when the generator starts.
Although the pump is self-priming, a dry start with 1.5 m. suction height will rapidly wear the impeller.
hydro-generator HuwFernie DIY Marinizing 10 01-12-2012 06:17 AM
Easy 12 or 24 v generator pistnbroke Electrical Systems 5 03-06-2011 05:08 PM
wind generator luso Marketplace 0 06-18-2008 02:09 PM
generator installation Wild Bill Electrical Systems 0 02-16-2006 07:53 PM
Portager's Generator Portager Electrical Systems 0 07-24-2003 12:19 AM
