Old 01-01-2008, 09:21 PM
chris083210 chris083210 is offline
Rep: 10 Posts: 2
Fishing torpedo - wiring issues
Hi all,
I'm having trouble with the wiring in a fishing torpedo that i've made. I have a 12vdc 200w mercury motor, running off 2 12vdc 7ah batteries in parallel. So the voltage across the motor is 12v.
The problem comes from the timer, which is in the circuit, which allows me to control how long it is set for. This is a mechanical (manual)timer, but has been getting extremely hot in test runs and has been cutting out because of too much current flow.
Im trying to find a way that i can use the timer in a sort of control circuit, while most of the current flows to the motor without going through the timer.
I would appreciate any ideas/wiring diagrams out there, as this has got my project completely on hold.
-Chris
Old 01-02-2008, 10:02 AM
TerryKing's Avatar
TerryKing TerryKing is offline
On the Red Sea!
Rep: 278 Posts: 581
Location: King Abdullah University of Science & Technology - Near Jeddah, Saudi Arabia
Resistance??
What kind of timer is this? If it's one designed for 120 VAC, typical house/light use, that's why it's getting hot: too much current.
Easy Kmart/Auto store solution is a 'headlight relay' or equivalent. A small box with 'Switch contacts" for your motor, and a control-coil contact to turn it on and off, which your timer can do.
Many of these have those 1/4" tab contacts which you can get crimp-on connectors for, so wiring should be pretty easy....
IF this is what you're doing!! Let us know what works out,....
Regards, Terry King ...On the Red Sea at KAUST
Old 01-02-2008, 03:05 PM
thudpucker's Avatar
thudpucker thudpucker is offline
Rep: 343 Posts: 724
What's the timer for?
Old 01-05-2008, 06:00 PM
Rep: 10 Posts: 2
Thanks Terry, I've since wired it up with a relay, and that seems to do the trick. I had to do a bit of hunting to find out which way to wire it, but it seems to have diverted all the current past the timer, while the timer still works and cuts the power when it runs out.
Thanks all
-chris
300knt torpedo zerogara Boat Design 139 02-08-2010 12:37 PM
Albert Hickman Torpedo Boat hick seaslead Boat Design 7 06-15-2006 05:59 PM
torpedo Shuggy Propulsion 12 10-20-2005 06:29 PM
Want to add a torpedo stern to a 30' cape lsland lobster style boat rbeck Boatbuilding 0 09-01-2004 04:07 PM
Stability Issues mrbrown Boat Design 17 08-12-2004 11:15 AM
