philSweet
- Joined
- May 2, 2008
- Posts
- 3,013
- Reaction score
- 715
- Location
- Beaufort, SC and H'ville, NC
The trick is to minimize paralleling of batteries. Most are just not inherently fail-safe if paralleled. RVs and boats and diesel pickups often parallel two batteries without fuses. In separate enclosures or in an open bay, this does not seem to lead to fires during a short using deep-cycle batteries or even start batteries in pickups. If you find yourself wanting to parallel more than two, get bigger batteries. Or shift to higher voltages. The cost of fuses and wiring for a many-in-parallel scheme that actually will do the job reliably and not cause other bothers in a typical marine installation would be much greater than just going to a different configuration.
And yes, you typically have to replace all the batteries in a bank unless you are standing there when the fault occurs, so I tend to overwork a smaller bank and replace it more often. I'd rather replace two batteries every two years than three every three years, which is about what happens running the banks at equal power draw cycles. This is another way to reduce paralleling.
Another issue with parallel strings is charging. You are less likely to create an over-current condition in a 2 in parallel configuration than in a many-in parallel configuration with the charger when one cell dies. Modern chargers can detect bad batteries and shut down, but not if the batteries are in parallel.
from rowerwet:
Which is why you need to destructively test complete installations, not just components, because geometry matters. Imagine for a moment about 20 sub batteries arranged in a ring around a missile in a silo. Then a short. Current rise on the order of 1 billion amp/sec. Peak current on the order of 1 million amps going in a circle around the missile. That's quite a decent inductor, with a 100,000 pounds of rocket fuel that is ignited electrically sitting in the middle. The mechanical stresses are pretty substantial as well. It happened, once. Fortunately, the place is designed to take an EMP pulse of similar magnitude. The configuration was redesigned after that.
from rowerwet:
The cells were being torn apart by magnetic fields induced by high current.
