| electrical ref. Recentely I have bought a 48ft motoryacht equipped with two diesel engine . I need to redo the electrical wiring for the whole boat ( engine and other components , 12V and 220V ). Could someone please refer me to an easy electrical book which explain step by step the method of wiring boats |
| Rebuilding Electrical System Toussy, there's a beginning of an Electrical Systems section of the boatdesign.net Wiki, but it's very incomplete. It may help later. Start with http://newboatbuilders.com/pages/elect.html and I would look at his suggestions about books. Also, http://www.yachtsurvey.com/boat_battery_basics.htm is a good source about batteries. When you learn something that you think is missing in the Wiki (And you'll learn a lot rewiring that boat!) add it to the Wiki...
| I would strongly recommend you seek the services of a skilled marine electrician (not a land based electrician, there are substantial differences and requirements). The level of electrical complexity, in a 48' twin diesel yacht, is quite extensive and beyond the scope of a book or the ability of a novice. You may have considerable success re-wiring many of the branchs in your multiple systems. No book will provide a step by step manual, for the many systems and sub-systems aboard your vessel, there are just too many possible methods and techniques that could be employed, for each example. There are several books (some available here in the BoatDesign Book Store) that will provide an overview to the methods and techniques used. It would be a good idea to get a few of these and educate yourself about the systems and how they are assembled. Much of this information will be valuable in finding faults or correcting problems. In short, it takes considerably more then a book or two to develop the skills, or the knowledge necessary to understand and problem solve these systems. Yes, much can be done by the yacht owner, but a fair amount of it will be well past your understanding, even after several books have been absorbed. |
| as par said: the differance is on land they use why system ,on boats you must use delta system,,delta uses its own ground ,,longliner |
| Electrical systems | TerryKing | Wiki | 23 | 05-30-2010 11:30 PM |
| electrical | mrtywatz | Powerboats | 2 | 06-18-2006 07:30 AM |
| electrical problem | gasdok007 | Metal Boat Building | 5 | 04-17-2006 05:19 AM |
| Java on boat speed (REF) | Guest | Open Discussion: All Things Boats & Boating | 0 | 05-18-2003 09:47 AM |
| electrical | Electrical Systems | 5 | 02-12-2003 01:39 PM | |
