| Burnt Points I Have A 1986 Mercruiser 3.0 Liter Io My Problem Is That After A Complete Tuneup This Spring I Have Burnt Up 2 Sets Of Points They Are Geting So Hot That The Metel Is Turning Purple And They Are Burning Hole Thru Contact Area I Have Checked Voltage To Coil And It Is Around 10 Volts After Passing Thru Ballast Resitor Any Ideals What Could Be Causing This |
| Points being damaged... There are basically 3 components involved:
One or more of these is probably bad. More likely condenser or ballast resistor if the engine runs... Measure the ballast resistor resistance with a good meter, compare to a new one...??
| A set of points are the same for ballast resistor system or without. In other words the points will handle 13.8 volts without damage. However they wont handle continuous arcing from a high current. A damaged coil would cause a high current draw. |
| Burnt Points I Did Notice That The Coil Was Very Hot But The Problem Seems To Have Started After The Tuneup Plugs , Wires, Points ,condenser, Rotor Button, Dist Cap A Mechnic Friend Told Me That He Had Heard Of Bad Rotor Buttons Jumping Spark Back To The Points Which Cooks Them Very Quickly |
| It sounds like a bad condenser. If you haven't replaced the condenser you installed with a new one yet, take the old one and reinstall it. The circuit is simple. When the points ground the primary coil the condenser prevents the points from burning. A bad rotor button would probably only cause misfiring. Also make sure the condenser is well grounded. The condenser, I think, is where the problem will be found. Alan |
| Hot Coil Something is wrong here (But, you knew that :-)) My votes: Either the Coil has shorted turns, or the ballast resistor is bad. You said 10 volts on the coil; that's a lot; usually more like 6 after the resistor. Typical resistor is 1.0 to 1.5 ohms as I recall.. Make sure you tell us what you find out!
| Did you check the ballast resister off the coil or on. 10 V is fine. |
| Burnt Points I Took Everyones Advice And Changed The Coil, Points, Rotor Button, Cap Ballast Reistor And Condenser Took It For A Run This Weekend And After Getting Home Removed Points To Inspect Them They Look Good After Running About 2 Hours On Them |
| On the Water
| Rep Points re: westlawn thread | Frosty | Forum Questions and Suggestions | 3 | 01-07-2007 09:52 PM |
| lifting points - marking at hull... | User_U | Boat Design | 8 | 01-06-2006 03:59 PM |
| points cloud | Mirko | Software | 10 | 06-25-2005 07:59 AM |
| Points Of Interest For The Yacht Builders | kalin | Services & Employment | 2 | 06-17-2003 09:12 AM |
| Joining points in Prosurf | Willallison | Software | 2 | 09-09-2002 06:49 PM |
