Old 05-28-2006, 12:44 PM
jfblouin's Avatar
jfblouin jfblouin is offline
Rep: 24 Posts: 163
Battery wiring diagram for 2 outboards
I'm building a center console boat with 2 outboards motor.
I'm tinking about battery wiring diagram. My outboards are 85 HP 2 strokes Yamaha. I want to use a 1000 Watts inverter and electronics (Camcorder, computer, GPS) on boat for several hours.
How many batteries I need ? (cranking, deep cycle)
Does I need a cranking battery or I can use deep cycle batterie for motor ?
Can I put the two motor on the same big battery ?
Do you have suggestions ?
Thanks
Jean-Francois Blouin
PS Sorry for my not so good english
Old 06-02-2006, 05:06 PM
Rep: 1397 Posts: 7,216
The 1000W inverter will use about 10AH . For 10 hours of use you will need a battery or set of batteries that rate 100 AH. Deep cycle are better for this. You can use a battery isolator between the deep cycle house batteries and the starting one.
Old 06-02-2006, 05:57 PM
yipster's Avatar
yipster yipster is online now
Rep: 1027 Posts: 3,269
for 2 dynamo's use 2 separate batery's, think you can use a cross switch for starting on deep cycle batts
Old 06-05-2006, 08:41 PM
jfblouin's Avatar
Rep: 24 Posts: 163
Thanks for info
Yipster: What do you mean by cross switch ? It is A - B - Both - off switch ?
About isolator, I find this link http://www.noco.biz/InstallGuidesPDF...d%20marine.pdf
It is a very interresting link. I think about A diagram for one engine and regular mount for other one. The E diagram is better but more costly. Maybe I can add a swith to connect both cranking batteries in case of failure of one battery.
Old 06-06-2006, 02:07 PM
yipster's Avatar
good diagrams but apart from the master A - B - Both - off switch you can have a momentairy toggle switch on the dash witch parallels the battery's to assist in starting (from deep cycle?) dont even know if dynamo's this way run over the multi phase charger, am buying (deep cycle?) start battery's tommorow, hope the marina store knows. here's some more on battery's
Wiring Diagram scanvictoria Electrical Systems 2 06-12-2006 11:07 AM
ID this diagram? (Metacentric Shelf) Earl Boebert Sailboats 0 02-27-2006 10:19 PM
460 water hose diagram . Sagabu Powerboats 1 12-21-2005 02:40 PM
Hunter 36 Polar Diagram kenJ Software 0 07-07-2005 03:59 PM
Searching diagram Troost enz_tn Boat Design 3 04-25-2004 08:17 AM
