| battery conection In my yacht is one battery, I have a second battery and thought what better way would be to connect the two batteries. I have this battery selector switch http://www.svb.de/pictures/large/62b...a7be054b3c.jpg . but now I'm thinking maybe a better way would be to use Split Charge Diodes http://www.svb.de/pictures/large/e9e...18456fbd59.jpg And if I use Split Charge Diodes , the battery selector switch will no longer be used in conjunction with Split Charge Diodes . p.s my english isn't very good, but I hope you understand my question |
| You have a good, reliable solution with the Vetus switch. The diode bridge may be easier because it needs no intervention from you, but there is a voltage drop of 0.5-0.8 volts, so your batteries will not be fully charged anymore. To overcome that, you need to install another regulator (14.5 V) in your alternator.
| battery systems | shane blower | Projects & Proposals | 3 | 05-06-2008 06:44 PM |
| battery | m.s.j | Electrical Systems | 1 | 07-07-2007 11:35 AM |
| battery life | 3pepper | Boat Design | 2 | 01-20-2007 05:00 AM |
| Accessories/Battery help | thebassn8tr | Boat Design | 7 | 01-15-2007 08:55 PM |
| Battery safety | duluthboats | Electrical Systems | 10 | 08-16-2002 10:31 AM |
