Old 12-07-2008, 07:12 AM
stef1-11's Avatar
stef1-11 stef1-11 is offline
Rep: 10 Posts: 4
Another please help my wire my boat.
Hi,
I’m hoping some of you nice knowledgeable people could help me wire up my boat. I recently restored it and 80% of the wiring is still there it just needs to be connected.
The engine is a 24 volt inboard diesel. At the moment I can start it by touching a wire from one of the batteries on to the appropriate part of the solenoid.
I would like to be able to start the engine with a key and wire the alternator to charge the batteries. If I get that far then I’ll look at the gauges and glow plugs, etc.
Sorry the Alternator and Solenoid aren’t marked, and I’m not sure what the thing under the Battery selector is, but one of the old batteries is still wired to it.
Finally I may be missing a few thing and will add to the diagram as they come to light.
If anyone could help me it would be much appreciated.
I'll will update the diagram as people suggest.
Thanks .
Another please help my wire my boat.-boat-electrics.jpg  Another please help my wire my boat.-alternator.jpg
Old 12-07-2008, 07:28 AM
rasorinc rasorinc is offline
Rep: 682 Posts: 1,130
Would it be possible for you to draw up a diagram of what you now have and scan and post it? With out knowing what you have makes it difficult to give any advise. Stan
Old 12-07-2008, 08:25 AM
TeddyDiver's Avatar
Gollywobbler
Rep: 1298 Posts: 1,991
And far better advices than anyone can give you in any forum can be found in literature. Like Boatowner's Mechanical and Electrical Manual by Nigel Calder. Maybe the best used $35 investment for a boat ever..
Old 12-08-2008, 06:21 AM
stef1-11's Avatar
Rep: 10 Posts: 4
Thanks anyway, I think i'm pretty close to sorting it out. I will post completed diagram soon.
Old 12-29-2008, 04:49 PM
stef1-11's Avatar
Rep: 10 Posts: 4
probably not right but seems to work
Old 12-30-2008, 04:14 AM
CDK's Avatar
CDK CDK is offline
experimental engineer
Rep: 1316 Posts: 2,145
The temp gauge is wired to both + and -, the oil gauge has just 1 wire. I guess they both should be connected to + only. That + should be behind the key switch.
The volts gauge should be connected between + (switched) and -. In the drawing it is wired as an amp. gauge.
What is the circle marked glow plugs? Is that a pushbutton or a special relay? That part carries a lot op Amps, approx. 20 Amps per cylinder.
Old 01-07-2009, 05:00 AM
stef1-11's Avatar
Rep: 10 Posts: 4
Thanks CDK
Temp and oil gauge OK except, as you said to ignition, otherwise battery goes flat if not isolated (expensive mistake).
I hooked up the volt gauge how (I think) it was hooked up before i took the engine out. Someone said something simular when i showed them.
Yes glow plugs is a push button but i dont use it because it dosn't seem to work.
Thanks for the advice, I will definitely get volt meter and glow plugs sorted out before i go much further and update diagram.
What to use to crimp 8 AWG wire? Brylk1830 Electrical Systems 18 11-20-2008 12:52 AM
good source for wire jk0529 OnBoard Electronics & Controls 2 03-24-2008 10:07 PM
Aluminum Mig Wire jmac Metal Boat Building 8 06-06-2006 12:27 PM
Opinions on Saving Old Wire JC47 Electrical Systems 3 03-22-2006 10:14 AM
Welding Wire Arrowmarine Metal Boat Building 2 09-03-2004 02:01 AM
