View Poll Results: Which AGM battery make do you prefer?
Optima 3 37.50%
Lifeline 1 12.50%
Odyssey 1 12.50%
Other 3 37.50%
Voters: 8. You may not vote on this poll
Old 05-17-2009, 04:48 AM
Jeff's Avatar
Jeff Jeff is offline
Moderator
Rep: 921 Posts: 1,371
AGM batteries: Optima vs. Lifeline vs. Odyssey
I'll soon have to replace a pair of (cheap) batteries and am thinking of going with AGM for their ability to sit idle for a while without losing much charge when I'm too busy to go out or when we get a cold period spring and fall. I do not know much about batteries and am considering a pair of Optima D31M, Lifeline GPL-31T, or Odyssey PC1500MST, though the latter is getting a bit pricey for my budget. These also are probably a bit overkill for my needs (will mostly just use them for starting and pumps and electronics and powering computer & external wifi antenna) but I like having a bit more battery than I'll hopefully need. (except for the possible tax it could put on my stock mercruiser alternators with the AGMs if I do draw one down all the way.)
Anyone have a good review comparison of Optima vs. Lifeline vs. Odyssey in general?
Old 05-17-2009, 04:54 AM
Landlubber's Avatar
Rep: 1491 Posts: 2,449
Try a price on Trojan batteries too, I have used and recommended them for many years now.
Old 05-17-2009, 05:21 AM
Jeff's Avatar
Moderator
Thanks Landlubber! The name is familiar but I haven't seen one around here in a while. Will have a look at their pricing. Thanks.
Old 05-17-2009, 09:14 AM
Rep: 472 Posts: 1,391
Optimas, are easy to get at most autoparts... They work fairly well, I like Blue tops. Don't know much about others.
Old 05-19-2009, 09:30 PM
Jeff's Avatar
Moderator
Just ordered a pair of Optima blue tops. I've heard some great comments about the Odyssey batteries but the cost was 50% greater.
Old 09-12-2009, 07:30 PM
masalai masalai is offline
masalai
Rep: 1630 Posts: 7,322
My present choice is Optima D34M, but I do not anticipate purchasing till nearer launch date in April 2010, so I am still open to better options (capacity & rate of accepting a charge) as I will have 20 of them and desire the best "bang for the buck" - - They are spiral wound and around 20kg each... but there may well arise better options...
Try to be helpful... The trouble with people is to realise and remember that there are at least two sides for every story...
A woman's breasts, one is not enough, - two may be just right, - but dreaming of 3 is a pleasant fantasy...
Old 09-12-2009, 11:43 PM
mark775
For "bang for the buck" you may want LI-ion!
Old 09-13-2009, 12:56 AM
masalai
Mark, thanks for the thought and suggestion, but not at present, - - technical requirements for charging and mid-stack failures and over here the price is horrendous when 48v 220 AH or better is considered... especially when the controlling and management circuitry is included as opposed to a relatively cheap controller for lead acid...
lifeline height dreamer Boat Design 17 03-28-2009 04:51 PM
Looking for Deep cycle high cap batteries AGM or Gel in stock ekraus Materials 0 08-16-2008 01:38 PM
Marine Batteries philzero44 Electrical Systems 6 08-02-2008 10:38 PM
Batteries in Parallel seanform OnBoard Electronics & Controls 6 04-27-2008 01:50 AM
Bonding a Jeanneau Sun Odyssey 40 Sean Herron Boat Design 1 08-03-2006 04:54 AM
