Old 10-11-2016, 11:53 AM
Setsail53 Setsail53 is offline
Rep: 10 Posts: 4
24v double pole
I'm renovating an swan 53 with double pole 24v system. My question is : why are my volt D.C. Volt meters reading 48v?
Old 10-11-2016, 12:58 PM
Rep: 2031 Posts: 11,798
That would mean there are two 24V setups in series. Can you post photos of the batteries and connections?
Old 10-11-2016, 02:39 PM
Rep: 10 Posts: 4
Have 3 banks service start and radio. Each reads 48 on onboard volt meter. Even with batteries disconnected and just one of the chargers on it reads approx. 48v or just one 24v bank connected 48v. With multi meter reads 24v on terminals. I'm thinking bad meter onboard?
Old 10-11-2016, 03:59 PM
If the voltmeter doesn't change even when you disconnect the batteries I would suspect it is bad. Disconnect the wires behind the voltmeter and see if anything changes.
Old 10-11-2016, 04:12 PM
Rep: 10 Posts: 4
Nothing changes. Volt meter will be changed.
Old 10-12-2016, 08:25 AM
Rep: 575 Posts: 2,160
Sometimes it is the simple things.
Double Pole 24v Dc System LongJohnSilver Electrical Systems 13 02-13-2012
03:13 AM
24v Battery Configuration SeaJay Electrical Systems 5 06-10-2011
01:40 AM
Single pole and 2 pole conflict watchkeeper OnBoard Electronics & Controls 82 11-14-2010
12:19 PM
12v/24v russglass All Things Boats & Boating 2 01-09-2009
02:17 AM
24V and 12V wallguy31 Electrical Systems 20 04-09-2007
09:46 PM
Powered by: vBulletin Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
Web Site Design and Content Copyright ©1999 - 2017 Boat Design Net
