Old 07-06-2010, 12:00 AM
SeaJay SeaJay is offline
Rep: 112 Posts: 211
12v Circuits - Rules of Thumb?
I’m starting to conceptualize the wiring for the 46’ motorsailer I have under construction and am somewhat at a loss when dealing with 12v wiring strategies. I’ve done a fair amount of 120v residential wiring where wire size and voltage drop are pretty straight forward…you grab either the 12g or 14g and start pulling. However, I can’t see yanking a bunch of 8g boat cable to every light fixture on the boat, so maybe someone can point me in the right direction.
IN GENERAL, is it more efficient (in the fullest sense of the word…i.e. Initial cost, energy use, labor, maintenance, weight, complexity, reliability, etc.) to pull a lot of small individual circuits from a centrally located panel, or is it more desirable to use a few perimeter circuits with larger cable and junction boxes/subpanels to supply the individual users?
Are there some rules of thumbs like in residential wiring where you generally put the lights on one set of circuits and the duplex outlets on another?
Regards,
SeaJay
Old 07-06-2010, 03:33 AM
CDK's Avatar
CDK CDK is offline
retired engineer
Rep: 1425 Posts: 2,252
There is one rule of thumb to be considered:
Your 12v circuit uses currents that are 10 times higher, so the wire cross section must also be 10-fold that of residential wiring.
Because normal fuses and circuit breakers have current ratings of 6, 10 or 16 amps the number of appliances that can be fed from one point is much lower than you are used to at home.
Old 07-06-2010, 10:26 AM
Rep: 112 Posts: 211
Thanks CDK. I wasn't aware of the issue of smaller fuses/circuit breakers. That helps explain why I see such massive amounts of wiring entering panels on boats.
Old 07-06-2010, 10:47 AM
KnottyBuoyz's Avatar
KnottyBuoyz KnottyBuoyz is offline
Provocateur & Raconteur
Rep: 578 Posts: 615
On smaller boats it's probably more economical to pull smaller runs to individual loads (one panel). On a larger boat, as you mention, running larger cables to supply separate nodes (buss's) is also common. You'll have to know the full load capacity of each node to correctly size the wire. I can see this is extremely advantageous on a cat where you're essentially wiring two separate boats. I have two buss's on my boat. One on the lower helm that supplies most of the boat's major systems and one on the overhead console that power most of the accessories. Both are fed from the main battery bank by individual circuits.
Generally a good idea as well.
Yours Aye! Rick M/V She:Kon Blog
"It's not the boat "you built" until you've sworn at it, bled on it, sweated over it and cried beside it!" - I just made that up!
Old 07-06-2010, 01:10 PM
Rep: 112 Posts: 211
Thanks Rick. I can see where on a cat the loads logically fall into a neat subdivision. For for some reason, I intutively want to use subpanels, although CDK's comments bear consideration.
Old 07-06-2010, 01:57 PM
Rep: 578 Posts: 615
You might want to look into this....
http://www.capi2.com/capi2/about.htm
Distributed power systems for yachts.
Old 07-06-2010, 02:06 PM
missinginaction missinginaction is offline
Rep: 417 Posts: 336
CDK is as usual correct. It's going to be difficult in this format to get you all the information you need. You allready have a leg up on many people with your understanding of 120/240 volt residential wiring.
I'd respectfully recommend that you go to a book store or your local library and find the following:
http://www.amazon.com/Boatowners-Mec...8442944&sr=8-1
This well written and comprehensive text will provide you with all the information that you will need to properly configure your boats electrical system.
With a boat of your size you might want to consider a 24 volt system.
Regards,
MIA
Old 07-06-2010, 08:59 PM
Rep: 112 Posts: 211
MIA,
I have, or I should say I had, lost, and have re-ordered Calder's book...a most valuable resource.
Knotty,
I've read a bit on the distributed systems and was interested in Calder's recent evaluation of the one he installed on his boat. They sound appealing with their promises of simplicity but I don't know if I'm quite sold on them. Nonetheless, they do seem to address the issues I'm concerned about. I don't have to make any decisions today so I'll keep an open mind.
Old 07-06-2010, 09:38 PM
Rep: 578 Posts: 615
Knotty,
That was just something I stumbled across awhile ago. I'm not sure either but there seems to be something there worth investigating. I think KISS is in order when doing that kind of wiring. 120 VAC and I don't get along.
Old 07-07-2010, 10:12 AM
Rep: 112 Posts: 211
Knotty,
Yes, KISS is the order of the day. Electrical problems can be such a headache to resolve which is why I want to really simplify and bullet-proof my wiring when I put it in.
(RINA RULES)Rules for the Classification of Floating Docks linxiao Class Societies 0 03-03-2010 05:52 AM
Bruce Robert's Tom Thumb Steelfloats Metal Boat Building 4 04-07-2008 05:14 AM
RULES of THUMB mdatrpz Boat Design 15 02-11-2008 08:29 AM
Adding Headroom to Thom Thumb 24 timgoz Metal Boat Building 2 10-13-2006 10:06 AM
Can I have a thumb nail lakerunner Option One 0 01-09-2005 12:40 PM
