Old 04-16-2006, 10:03 AM
gasdok007 gasdok007 is offline
Rep: 10 Posts: 24
12 volt dillemma
I'm trying to troubleshoot an electrical problem - aluminum hull, twin honda outboards, two batteries.Boat is out of water on trailer. Port battery keeps draining and dying.This is also the housekeeping battery,but with battery switches off there is no current draw.I'm thinking that the engine rigging may be wrong.The port ignition must be on in order to power the starboard ignition,and when the battery ground is connected to the motors (or either motor) ther is continuity between the + terminal and the metal hull( my test light goes out when I disconnect the negative to the motor).My understanding is that the negative ground should be isolated from the metal hull.Do the mounting brackets tie the ground to the hull or is something else wrong? Any thoughts appreciated.
Old 04-16-2006, 12:00 PM
Rep: 505 Posts: 1,658
have you had the cells checked in the one battery ? even new ones can be bad
Old 04-18-2006, 03:31 AM
Tim B Tim B is offline
Rep: 763 Posts: 1,384
Sounds like something is shorting the battery. A simple check is to disconnect one side of the battery and put an ammeter in the circuit (at the battery). If there is no current flowing at the battery, take it out and see if the same thing happens on the work-bench at home.
Tim B.
Old 04-24-2006, 08:20 AM
Rep: 1397 Posts: 7,215
The hull is connected to the negative ground. That is the correct setup. The test light is not showing continuity but voltage difference. That is correct too.
Old 04-25-2006, 10:42 AM
solrac solrac is offline
100% sudaca
Rep: 42 Posts: 138
maybe cheapest solution, install a 2 pole-circuit breaker & isolate both positive + negative battery pins...
Old 04-25-2006, 11:25 AM
If the battery is draining, you need to find the problem. It shouldn't happen if the system is installed correctly. What may appear to be a cheap and fast solution could create a worse more expensive to repair problem.
Power Sports Advanced Battery Charging System 12 Volt wingstech Marketplace 0 04-21-2005 09:48 PM
