Closed Thread
Old 05-07-2012, 06:21 AM
SudorracMechEng SudorracMechEng is offline
Rep: 15 Posts: 22
wiggle drive
Hi, i was looking at using the wiggle drive for a surfboard application - whereby two fins could be oscillating and a system will be in place to lock the fins in initial position once desired speed is achieved.
I am a final year mechanical engineering student, I am wondering which principle is used for the following: (ill try my best to explain)
The two fins will be Vertically mounted, they will flap from left to right and the pitch will be around +- 15 degrees.
It will be running off the same idea as this video
http://www.youtube.com/watch?v=DtD09MTUsnE
Old 05-07-2012, 07:57 AM
Rep: 1734 Posts: 8,386
You should only post once. It makes it very confusing otherwise.
Old 05-07-2012, 12:17 PM
Boat Design Net Moderator Boat Design Net Moderator is offline
Moderator
Rep: 799 Posts: 273
To keep the discussion together, let's have the discussion continue in the one thread at wiggle drive propulsion application
Please be polite to all other members. Please respect those who take their time to give advice freely. And please keep threads on topic. Forum Rules
Last edited by Boat Design Net Moderator : 05-07-2012 at 12:18 PM. Reason: Duplicate / cross posted thread
Closed Thread
wiggle drive propulsion application SudorracMechEng Propulsion 304 08-17-2012 05:45 AM
Chain drive,Universal joint,Direct drive Ed-H DIY Marinizing 3 03-14-2010 09:48 AM
keel wiggle Guest Sailboats 10 03-04-2004 01:46 AM
