Old 08-29-2005, 09:15 PM
tom kane's Avatar
tom kane tom kane is offline
Rep: 265 Posts: 865
As a DIY solution to exhaust problems the choice is yours.Running a Turbo after a water jacketed exhaust manifold,with heat loss is common.You have to accept compromises with Turbos anyway,and install the best option you can get (even a water cooled Turbo if you want it.The choice and variety of configurations is massive in diesel engines.
Is Exhaust Gas Recirulation a good option for emission control?it is an old idea.
ECU settings can be varied for optimum running of motors.
There should be no disadvantages using a metal-shroud/water-jacket exhaust manifold if thermal efficiency is taken into account when designing running gear.
tomkane
Old 08-30-2005, 05:33 AM
Carioca Carioca is offline
Rep: 26 Posts: 59
The reason I brought up this subject is that a friend is about to do a DIY marinisation on a 6-cylinder automotive-type 6 cylinder diesel engine rated at 180 HP/3600rpm.
He doesn´t want to lose any available power. Also, wants to stay away from the (potential!) mess of having fresh or raw water in intimate contact with the exhaust manifold.
I told him to use a water-cooled metal-shroud.
I have seen it done on a 6-cylinder Cummins 6 BTA. Apparently, so far so good.
Old 08-30-2005, 08:43 AM
Rep: 700 Posts: 3,208
Many of the newer exhaust wrapping systems will keep a dry exhaust manifold cool enough to not overheat the engine space, or start a fire.
Simplest and most reliable is the wet exhaust manifold that is cooled with a slightly larger sized keel cooler.
This is the choice of commercial boats around the world, cheap quick , low risk , and best of all it doesn't need anything ('cept antifreez in the cooling system) to operate in winter where a sea water system would need service with each shutdown.
While there are fine low drag hi $$$$ keel coolers ,
in Maine, 2, 20ft runs of 1 1/2 pipe works well at very low cost.
Lasts a decade or more if painted.
FAST FRED
Old 08-30-2005, 10:52 AM
Rep: 26 Posts: 59
Many thanks Fast Fred. Do you know of web sites that carry exhaust wrapping material ?
Old 08-30-2005, 12:39 PM
Rep: 26 Posts: 59
Fast Fred, do not bother with my last request. GOOGLE solve the problem in a FLASH !
Wet Balsa Core Cliff Ruckstuhl Materials 2 07-11-2005 08:14 AM
Wet Balsa Core Repair Cliff Ruckstuhl Sailboats 3 07-10-2005 12:53 AM
Packajet exhaust manifold jetboatjill Open Discussion: All Things Boats & Boating 1 05-06-2005 10:40 AM
WET vs DRY thickness and fiber/resin ratio jfblouin Materials 1 02-14-2005 02:32 PM
Seacock manifold system kudu Boat Design 18 06-26-2003 10:43 PM
