Old 03-12-2010, 11:11 PM
Ed-H Ed-H is offline
Rep: 13 Posts: 15
What's that thing on the shaft of a longtail
I have noticed on some of the larger long tails something that appears to possibly be some sort of reservoir up near where the drive shaft attaches to the motor. Can anyone clarify what this thing is, why it is there, where one can obtain them?
Old 03-13-2010, 12:32 AM
Frosty's Avatar
Frosty Frosty is offline
Rep: 1693 Posts: 5,867
Every longtail is different, many engines many ideas from different regions, Malays have them too, and probably Indonesia.
The bigger ones have a heat exchanger with a pump on the front crank pully , a discharge pipe just hangs over the side.
I saw a guy just the other day attach his alternator belt while the engine was running, he has obviously done that before almost faster than the eye.
How he gets it off I have no idea.
Old 03-13-2010, 07:48 AM
TeddyDiver's Avatar
TeddyDiver TeddyDiver is online now
Gollywobbler
Rep: 1348 Posts: 2,054
Open the alternator tightening screw, turn the alternator towards the engine. Now you can place the belt, turn alternator back "out" and the new belt starts to run, tighten the screw..
ps.. count your fingers before an after. If there's a missmatch don't do it again
Old 03-13-2010, 08:22 AM
Frosty's Avatar
No --he did it in a split second, decided he wanted to charge the battery, picked up the belt and popped it on. All while the engine was fast idle.
He put the belt on the double water pump pulley first then slipped it onto the alt.
I suppose he does'nt need to charge the batter all the time being a diesel and NO other electrics.
Old 03-13-2010, 09:18 AM
licensedtochill licensedtochill is offline
Rep: 11 Posts: 3
I believe it is an oiling cup for the bearings inside of the motor to shaft adapter.
Old 03-13-2010, 11:19 AM
TeddyDiver's Avatar
Gollywobbler
No --he did it in a split second, decided he wanted to charge the battery.
Might just be the alternator being loosed to turn at will allready and just the weight of it being adequate to give the friction for the belt?
Old 03-13-2010, 11:37 AM
Previous Member
Rep: 0 Posts: 0
Something like this?
http://www.youtube.com/watch?v=Xzo6a16IZgg
I learned this trick when I worked as a VW/Porsche mechanic back in the early 70's. Crappy technique can send a screwdriver flying across the shop, or worse.
Old 03-13-2010, 12:01 PM
TeddyDiver's Avatar
Gollywobbler
wow!!
Old 03-14-2010, 10:54 PM
Rep: 13 Posts: 15
Thanks L2C, I thought that might be what it was. I seem to remember reading about some type of expansion chamber for when the lube gets heated and expands, so as not to blow out seals. Does this sound like a possibility?
Angle of engine on a longtail straight shaft mud motor? simplebobby86 DIY Marinizing 6 10-25-2009 01:46 PM
Longtail boat question tomac Boatbuilding 3 09-20-2009 05:09 AM
Longtail motor angle licensedtochill DIY Marinizing 11 06-28-2009 03:29 PM
Longtail thailand tabanaza Boat Design 0 04-15-2009 07:57 PM
weedeater longtail caveman DIY Marinizing 8 10-01-2006 05:32 PM
