Weed eater engine conversion
Discussion in 'DIY Marinizing' started by Ward, Jun 2, 2003.
  1. Harshana
    Likes: 1, Points: 0, Legacy Rep: 25
    Harshana Junior Member
    Yes Hoytedow, I'm happy with the speed.
    Thanks,
    Harshana
  2. Ironmule
    Ironmule New Member
    An alternative
    I've read this thread from start to finish, and I will soon be constructing weedeater powered longtail, but I'm struck by the fact that there's been no mention of the low tech alternative for getting up a stream in shallow water: the push pole.
    http://www.youtube.com/watch?v=nMxURxbzBWo&feature=player_embedded
    Good, it worked. I plan to have a bamboo pole in adittion to the much muffled weedeater longtail.
    Jeff Smith
  3. pistnbroke
    Likes: 40, Points: 48, Legacy Rep: 404
    pistnbroke I try
    Maybe that because its a thread about weedeaters not push poles
  4. hoytedow
    Have push poles reached the apex of their development? Yes. It happened when the propeller was applied and it was made to spin.
  5. ben2go
    Likes: 4, Points: 18, Legacy Rep: 13
    ben2go Boat Builder Wanna Be
    Let us not forget about their short comings in deep water.
  6. hoytedow
    People learned to flatten the ends of their push poles and turned them into paddles.
  7. parkland
    Likes: 6, Points: 18, Legacy Rep: 40
    parkland Senior Member
    Maybe I missed it, but what about the bearings in the weed eater?
    Wouldn't they wear out real quick in water?
  8. hoytedow
    Weed eater bearings under water can be a greased wood bushing further lubricated by water.
  9. Mark Wo
    Likes: 5, Points: 0, Legacy Rep: 56
    Mark Wo Senior Member
    Wow, I got tired and am sore just watching that guy push pole upstream. I do have a question, why didn't he float downstream to take the pics he did? Why work so hard to go upstream?
    Mark W
  10. xkilo155
    xkilo155 New Member
    Ward, go to Youtube.com. And type in Weed Eater motor for boats....
  11. threedogs
    Likes: 2, Points: 0, Legacy Rep: 30
    threedogs Junior Member
  12. ben2go
  13. threedogs
    I'm not big on imagination so if you have any advice please share it with me. :)
  14. ben2go
    Everything is in this thread on different ways to build the motor you linked to,plus a few alternatives.
  15. buttales
    Likes: 2, Points: 0, Legacy Rep: 40
    buttales Junior Member
    i still have my old islandhopper outboard from back when they still sold to california. back then they had 2 stroke bridgestone titan motors, i have their 35cc version. the motors they have now are 4stroke but the prop and gearcase are the same as before. the prop is about 7in 3blade for an electic trolling motor...way overpropped so i would say no r&d work on prop performance was done by island hopper. as far as building the same exact outboard for 150 bucks could u post who u source from? the lowest price i could find for a 50cc 2stroke from monsterscooter was 125
